AUDIOPHONICS PSU-HC Regulated Linear Power Supply 5V 5A 60VA
This PSU-HC regulated linear power supply provides a clean and stable 5V 5A output voltage and current. At the output are two DC jack connectors, one in 5.5/2.5mm format and the other in 5.5/2.1 format to adapt to different configurations.
By buying this product you get 26 loyalty points
Reference : 13407
269,00 €tax incl.
224,17 € tax excl.
AUDIOPHONICS PSHP Alimentation Linéaire régulée RaspTouch 5V 4A 60VA
This PSHP regulated linear power supply provides a voltage and output current of 5V 5A. At the output are two DC jack connectors, one in 5.5/2.5mm format and the other in 5.5/2.1 format to adapt to different configurations.
The use of such a power supply in an audio system is a real plus in terms of playback quality. Indeed, providing a clean and stable electrical signal, it allows a reduction in background noise and a lowering of the ripple harmful to jitter on digital audio devices such as a DAC or a high-fidelity streamer. In use, we notice an improvement in the readability of the high-pitched midrange with a less digital sound, a beautiful base of the tones as well as a better bass dynamics.
Under the hood of this power supply are hidden quality components, ideal for audio use, and allowing this power supply to provide such performance. There are metal resistors, 10 6000µF/35V filter capacitors, a Micrel MIC2975BWT  voltage regulator and an EMI/RFI filter.
These components are integrated into a robust and robust brushed and black anodized Aluminium housing with the most beautiful effect. To dissipate the heat from the components, the cover of the unit incorporates slots and the side of the unit is equipped with a heat sink. This careful design allows this regulated linear power supply developed by our team to compete directly with more expensive solutions.
The female DC jack connectors of the PSU-HC require the use of cables with a long male DC jack connector (14.5mm).
Product typeRegulated linear power supply
Input voltageAC 220V (IEC Cable sold separately)
Output voltage5V DC / 5A (7,5A max, thermal limited)
Outputs1x Jack DC 5.5/2.5mm
1x Jack DC 5.5/2.1mm
Transformer60VA
Voltage regulatorMicrel MIC2975BWT
MaterialBrushed and anodized Aluminium
Dimensions240x170x60mm
Weight2,4kg
InputIEC C14
OutputJack DC 5.5/2.5mm
OutputJack DC 5.5/2.1mm
Output voltage (V)5.0
Output current (A)5.0
Input voltage (V)230.0
Power SupplyLinear
2 reviews
Node2021
Respire la qualité
This review has been posted for AUDIOPHONICS PSU-HC Regulated Linear Power Supply 5V 5A 60VA
Jyrki
The transformer was loose and allowed to move and rattle inside. Just a little tightening of the screw and the problem is gone.
The power supply supplies power to the Volumio Rivo network player and the Pro-Ject Pre Box S2 Digital DAC.
The power source opens up the sound and brings more separation. It feels like there is more power and the dynamics increased. Hears more details in the recording.
I recommend.
This PSU-HC regulated linear power supply provides a clean and stable 5V 5A output voltage and current. At the output are two DC jack connectors,...
