HiVi SWANS B3S Wide-Band Aluminum-Magnesium Speaker 3 "
HiVi B3S Haut-Parleur Large-Bande Aluminium-Magnésium 3"
4802
25,00 €tax incl.
20,83 € tax excl.
Available
Shipping date: 22-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
https://www.audiophonics.fr/images2/Swans_Logo.gif
Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Ultra rigid cone made up of aluminum and magnesium alloy coated on the surface with a damping material promoting dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor consisting of 2 magnets mounted in symmetrical and ventilated
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
https://www.audiophonics.fr/images2/4802_SWANS-HIVI-B3S_1.jpghttps://www.audiophonics.fr/images2/4802_SWANS-HIVI-B3S_2.jpg
 https://www.audiophonics.fr/images2/4802_SWANS-HIVI-B3S_3.jpg
Specifications:
  • Nominal Impedance:
  • Resonant Frequency: 80Hz
  • Rated Power:15W
  • Sensitivity (2.83v / 1m): 82dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 20mm
  • Length Coil:9mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:2.9
  • Hey :3.0mm
  • XmaX:3.0mm
  • Cms:1260
  • Qms:4.29
  • Qes:1.19
  • Qts:0.93
  • Mms:3.1g
  • Sd:0.0030m2
  • Vas:1.6L
  • Recommended Type of Load: Close
  • Recommended Load Volume: 2L
  • Recommended Cut-Off Frequency -3dB: 80Hz
  • Weight:0.53Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
 https://www.audiophonics.fr/images2/4802_SWANS-HIVI-B3S_4.jpg
HiVi B3S:Dimensions
https://www.audiophonics.fr/images2/4802_SWANS-HIVI-B3S_5.jpg
HiVi B3S:Frequency Response
https://www.audiophonics.fr/images2/4802_SWANS-HIVI-B3S_6.jpg
HiVi B3S:Impedance Curve
Colissimo - TNT - SoColissimo
