HiVi SWANS B4N Widescreen Speaker Aluminum-Magnesium 4 "
HiVi B4N Haut-Parleur Large-Bande Aluminium-Magnésium 4"
29,00 €tax incl.
24,17 € tax excl.
Shipping date: 19-03-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Ultra rigid cone made up of aluminum and magnesium alloy coated on the surface with a damping material promoting dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
  • Nominal Impedance:
  • Resonant Frequency: 56Hz
  • Rated Power:25W
  • Sensitivity (2.83v / 1m): 85dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:10.4mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:5.1
  • Hey :4.0mm
  • XmaX:3.2mm
  • Cms:1114.1
  • Qms:3.91
  • Qes:0.63
  • Qts:0.52
  • Mms:6.8g
  • Sd:0.0053m2
  • Vas:4.5L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 5L
  • Recommended Cut-Off Frequency -3dB: 50Hz
  • Weight:0.9kg
HiVi B4N:Dimensions
HiVi B4N:Frequency Response
HiVi B4N:Impedance Curve
Colissimo - TNT - SoColissimo
