HiVi SWANS M4N Wide-Band Aluminum-Magnesium Speaker 4 "
HiVi M4N Haut-Parleur Large-Bande Aluminium-Magnésium 4"
Reference : 4808
29,90 €tax incl.
24,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
https://www.audiophonics.fr/images2/Swans_Logo.gif
Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Ultra rigid cone made up of aluminum and magnesium alloy coated on the surface with a damping material promoting dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
https://www.audiophonics.fr/images2/4808_SWANS-HIVI-M4N_1.jpghttps://www.audiophonics.fr/images2/4808_SWANS-HIVI-M4N_2.jpg
https://www.audiophonics.fr/images2/4808_SWANS-HIVI-M4N_3.jpg
Specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 69Hz
  • Rated Power:15W
  • Sensitivity (2.83v / 1m): 82dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 20mm
  • Length Coil:9.0mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:3.1
  • Hey :3.0mm
  • XmaX:3.0mm
  • Cms:1080
  • Qms:5.39
  • Qes:1.35
  • Qts:1.08
  • Mms:4.8g
  • Sd:0.0053m2
  • Vas:4.3L
  • Recommended Type of Load: Close
  • Recommended Load Volume: 4.0L
  • Recommended Cut-Off Frequency -3dB: 70Hz
  • Weight:0.60Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4808_SWANS-HIVI-M4N_4.jpg
HiVi M4N:Dimensions
https://www.audiophonics.fr/images2/4808_SWANS-HIVI-M4N_5.jpg
HiVi M4N:Frequency Response
https://www.audiophonics.fr/images2/4808_SWANS-HIVI-M4N_6.jpg
HiVi M4N:Impedance Curve
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)102.0
