HiVi U2S Wide-Band Speakers Aluminum Anodized 2 "
HiVi U2S Haut-Parleur Large-Bande Aluminium Anodisé 2"
36,00 €tax incl.
30,00 € tax excl.
Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Rigid cone, Anodized aluminum coated on the surface with a damping material promoting dynamic stability
Peripheral suspension in transparent rubber
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor in neodymium
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
  • Nominal Impedance:
  • Resonant Frequency: 290Hz
  • Rated Power:5W
  • Sensitivity (2.83v / 1m): 83dB
  • Resistance DC:/ B>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:6mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: neodymium
  • Magnetic Shielding:/ B>Yes
  • BL:3.0
  • Hey :2.5mm
  • XmaX:1.8mm
  • Cms:261
  • Qms:5.17
  • Qes:1.43
  • Qts:1.12
  • Mms:1.2g
  • Sd:0.0013m2
  • Vas:0.1L
  • Recommended Type of Load: Close
  • Recommended Load Volume: 0.2L
  • Recommended Cut-Off Frequency -3dB: 245Hz
  • Weight:0.1Kg
HiVi U2S:Dimensions
HiVi U2S:Frequency Response
HiVi U2S:Impedance Curve
Colissimo - TNT - SoColissimo
