HiVi SD1.1-A Speaker Driver Dome Tweeter Shielded 15W 5 Ohm 91dB Ø2.5cm
HiVi SD1.1-A Tweeter à Dôme Blindé 25mm
4.0 / 5
Reference : 3795
29,90 €tax incl.
24,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
https://www.audiophonics.fr/images2/Swans_Logo.gif
Integrated with HiVi's home theater range, the SD1.1-A tweeter is distinguished mainly by its semi transparent transparent dome surrounded by a ring of shock absorbing material.
It is capable of a linear frequency response up to 20Khz and demonstrates a level of realism and appreciable clarity.
Moving coil of25mm diameter cooled with ferrofluid
Double magnetic circuit fully armored allowing the unit to be used in a Multimedia or Home Theater configuration
Chassis in aluminum alloymachined to perfection
https://www.audiophonics.fr/images2/3795_SWANS-HIVI-SD1.1_1.jpghttps://www.audiophonics.fr/images2/3795_SWANS-HIVI-SD1.1_2.jpg
https://www.audiophonics.fr/images2/3795_SWANS-HIVI-SD1.1_3.jpg
Specifications:
  • Nominal Impedance:5Ω
  • Resonant Frequency: 1200Hz
  • Rated Power:15W
  • Sensitivity (2.83v / 1m): 91dB
  • Resistance DC:/ Strong>4.6Ω
  • Diameter Coil: 25mm
  • Mounting Type:Aluminum
  • Number of Layers:2
  • Composition Magnetic Circuit:Double Ferrites Armored
  • Magnetic Shielding:/ Strong>Yes
  • Recommended Cut-Off Frequency -3dB: 2000Hz
  • Weight:1.0Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/3795_SWANS-HIVI-SD1.1_4.jpg
HiVi SD1.1-A:Dimensions
https://www.audiophonics.fr/images2/3795_SWANS-HIVI-SD1.1_5.jpg
HiVi SD1.1-A:Frequency Response
https://www.audiophonics.fr/images2/3795_SWANS-HIVI-SD1.1_6.jpg
HiVi SD1.1-A:Impedance Curve
Speaker Power (W RMS)15.0
Speaker TypeRibbon tweeter
Impedance (Ω)5
Loudspeaker diameter (mm)25.0
Efficiency / Sensitivity (dB)91.0
étonné pour le prix!!!!!!!
reçu aujourd'hui et après quelques essais rudimentaires ce tweeter descend très bas malgré son dôme de 25 mm et dans une bonne linéarité, la face est en aluminium massif avec amorce de pavillon du plus bel effet à recommander merci audiophonics ;)
This review has been posted for HiVi SD1.1-A Speaker Driver Dome Tweeter Shielded 15W 5 Ohm 91dB Ø2.5cm
