Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Red
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø 3.6mm Red
This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high resistance to oxidation and corrosion.
Reference : 13436
4,50 €tax incl.
3,75 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Wiring Cable
Copper / Silver 4mm² PTFE Sleeve Ø 3.6mm Red
Fil de câblage Cuivre / Argent 4mm² Gaine PTFE Ø 3.6mm Rouge
This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high resistance to oxidation and corrosion. The conductor is covered with a PTFE insulating sheath to limit interference and therefore noise.
Product cableWiring cable
Conductor materialOFC Copper
Conductor platingSilver
Conductor section4mm²
Conductor composition49 x 0.32mm
Cable diameter3.6mm
Insulation sleeve materialPTFE
ColorRed
Operating temperature-65°C / 200°C
ConditioningSold per meter
Diameter (mm)3.6
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)4.00
Ground / ShieldingNo
A remarcable cable and a true bargain
I do a lot of DIY staff and I gave this cable a try, due to its large cross-section, silver plating and PTFE insulation. I have used it to make speaker and power cables and although I was already familiar with the sound quality of this kind of cable at smaller cross sections, I was totally blown away with this one. After all, the size of the cross section DOES matter. I dare to say that both power and speaker cables I made with it, are very close to the sonic signature of mid-priced Nordost cables, without their complexity and at a very small fraction of their cost. Speed, micro and macro-dynamics, transparency, spatial information, frequency extension in both ends, smoothness, rich timbre and very extended but also very clean and accurate bass. Beware though, as always when PTFE is present, the brake-in period is very long. Do not judge it in the first few hours of listening. It needs at least 20 hours just to start to open-up, especially in the bass section. And it will continue for the next 200-300 hours. So be patient and you will be richly rewarded. I hope that Audiophonics will keep this cable in their catalogue for a very long time.
This review has been posted for Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Red
This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while...
