NEOTECH BRDCC-22 Braided Flat Wiring Cable UP-OCC Copper Litz Wire 22AWG 0.32mm²
NEOTECH BRDCC-22 flat wiring cable UP-OCC PTFE 22 AWG
Neotech BRDCC wires are an excellent UP-OCC copper solution. Professor Ohno's UP-OCC process is recognized in the manufacture of high quality HiFi cables. Cotton (70%) and Polyester (30%) insulation provides an excellent finish to your high-end cable, while protecting it efficiently from mechanical stress.
2.0 / 5
Reference : 10655
7,50 €tax incl.
6,25 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Câble vendu au mètre
Neotech BRDCC-22
BRDCC cables have a Litz wire structure, being composed of strands that are electrically insulated from each other and braided. This technique limits the skin effect and consequently the energy losses.
The Neotech BRDCC series with flat plastic guide facilitates cable manufacturing, offering a very nice finish with a high mechanical strength UP-OCC copper braid. It can be used as a conductor or as a UP-OCC Copper braid with a Cotton sheath, in addition to the Neotech SOCT and SOST ranges of cabling wires.
Comparaison Cuivre OFC et Cuivre UP-OCC Neotech BRDCC-22 Fil de Câblage Plat Tressé Cuivre UP-OCC Fil de Litz 22AWG 0.32mm²
Product typeWiring cable
Conductor materialBraided UP-OCC Copper Litz Wire (purity = 99.99998%)
Insulation70% Coton
30% Polyester
Section22AWG (flat rectangular equivalent to 0.32mm²)
Internal dimensions0.27 x 1.21mm
External dimensions1.4 x 6mm
Voltage / Current300V 6.7A
ColorWhite and black
QuantitySold by the meter
Certificat d'authenticité OCC Dr. Ohno
Diameter (mm)N/A
Length (m)Sold by length
Number of conductors1
Insulation materialCotton
Insulation materialPolyester
ShieldingYes
Section (mm²)0.32
Ground / ShieldingYes
Déception
Au premier abord, cette tresse de blindage en cuivre UP-OCC avec gaine coton paraissait très intéressant pour réaliser des câbles symétriques de haute qualité. Cependant, il est quasiment impossible de faire glisser des câbles (ni mono-brin ni même multi-brins) à l'intérieur car la tresse de blindage vient s'accrocher. Il aurait fallu que cette tresse puisse disposer d'une gaine TEFLON pour éviter ce phénomène.
Pour votre information, il y a bien à l'intérieur de cette tresse un séparateur plat en plastique qui permet de diviser en 2 la section mais cela ne suffit pas pour faciliter le passage des câbles.
This review has been posted for NEOTECH BRDCC-22 Braided Flat Wiring Cable UP-OCC Copper Litz Wire 22AWG 0.32mm²
Neotech BRDCC wires are an excellent UP-OCC copper solution. Professor Ohno's UP-OCC process is recognized in the manufacture of high quality...
