ELECAUDIO RA-01S Suppressor IEC Silver Ø16.5mm
ELECAUDIO RA-01S Suppressor IEC Silver Ø 16.5mm
4.5 / 5
Reference : 10148
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
This Hi-Fi adaptor, developed in France, was created to be used with almost every cable in the market.
With this adaptor you can connect your cable directly to your device, suppress all your IEC connection or add another power cable to your device without the need of a compatible entry.
With the same format as an IEC connector, so you can change it in an easy way.
The cable is locked with the help of a clinch claw which supports cables from 12.5 to 15.5mm.
This clinch claw allows you cable to be always aligned and centered whatever it is the cable diameter.
Caracteristics :
  • Material : Aluminium
  • Silver Anodized
  • Dimensions : 50x23mm
  • Overall Ring diameter : 30mm
  • Acceptable cable diameter : 12.5 - 15.5mm
  • Center distance fixation : 40mm
  • Drill holes : M3
  • Weight : 22g
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticFemale
ConnectorN/A
Contacts Plating (Connector)N/A
Rated current (A)N/A
2 reviews
Bonne qualité. Il remplace le connecteur IEC pour alimenter ma barrette Dynamos X6000 directement.
Par contre, absence de réducteur et j'ai dù moi aussi mettre du scotch pour augmenter le diamètre.
This review has been posted for ELECAUDIO RA-01S Suppressor IEC Silver Ø16.5mm
bonne qualité de fabrication, par contre le serrage du câble n'est pas vraiment efficace ! monté sur câble In-Wall GIGAWATT + Gaine Tressée Extensible Nylon (PET) 10-18mm (diam 12.5/13mm), le tout glisse toujours malgré un serrage plus que dynamique, j'ai donc dû rajouté du scotch noir pour combler le jeu ! cher !
