AMP25 Class AB Integrated Amplifier 2x30W 4 Ohm Bluetooth 5.0 Black
AMP25 Class AB Integrated Amplifier 2x50W 4 Ohm
This small integrated amplifier AMP25 in Class AB is an affordable, high-performance and stylish solution. Its MOSFET-based amplification stage is capable of developing no less than 2x30W at 4 Ohm, allowing it to accompany many speakers without flickering.
4.9 / 5
Reference : 13420
159,00 €tax incl.
132,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the new version, the AMP25.2 Class AB Integrated Amplifier 2x30W 4 Ohm HDMI ARC.
AMP25 Integrated amplifier
Class AB 2x30W 4 Ohm / Bluetooth 5.0
AMP25 Amplificateur Intégré Class AB 2x50W 4 Ohm
This small integrated amplifier AMP25 in Class AB is an affordable, high-performance and stylish solution. Its MOSFET transistors based amplification stage is capable of developing no less than 2x30W at 4 Ohm, allowing it to accompany many speakers without flickering. An amplification stage that takes advantage of a symmetrical dual circuit to greatly limit interference and therefore ensure very low output noise. This design allows to obtain a precise and transparent reproduction, while developing a beautiful dynamic and a wide sound image.
For its connectivity, the AMP25 goes straight to the point by making it simple and efficient. There is therefore a Stereo RCA input to connect your source to the amplifier and at the output of the speaker terminals. However, the device is also equipped with a 6.35mm Jack plug for quality listening to headphones. All connectors are gold plated, ensuring good signal conductivity and excellent oxidation resistance.
The headset output and the speaker terminals are active simultaneously. Both are affected by the volume control.
All components are integrated in a solid solid anodized aluminum housing and cut from the black mass for the most beautiful effect. Its assertive angles and recessed volume knob give the AMP25 a strong and assertive design with the most beautiful effect.
1Right speaker output
2Left speaker output
3ON/OFF Switch
4Power supply connector 12-14V DC (Power supply sold separately)
5Headphone output
6Stereo RCA Input
7Volume button
Product typeIntegrated amplifier
ClassAB
Output power2x30W / 4 Ohm @ 12V (1% THD)
THD0.008%
Frequency response6Hz - 80kHz (-3dB)
Input1x Stereo RCA / Bluetooth 5.0
OutputSpeaker terminals
1x Jack 6.35mm (headphone output)
Power supply connectorJack DC 5.5/2.5mm
Dimensions130 x 151 x 44mm
Weight1150g
MaterialMassive Anodized Aluminium
Package1x AMP25
1x Jack 3.5mm to Jack 6.35mm adapter
1x Bluetooth Antenna
1x 1x 220V power adapter (Power cord not included, available here)
OutputJack 6.35mm
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipMOSFET
Power (W)30.0
7 reviews
la multiamplification démocratique
1l amp pour l aigu ruban amt pro 4 et un autre pour le suraigu fostex t 90..résultat fantastique.mieux que de bons vieux classe A.
Et en prime un look sympa et une très bonne finition.
Trop fort les chinois.
This review has been posted for AMP25 Class AB Integrated Amplifier 2x30W 4 Ohm Bluetooth 5.0 Black
Excellent
Rapport qualité prix imbattable
surprise !
Bonjour, ...... oui grande surprise.
Excellent amplificateur, sur les premières heures d'écoute: grave excellent, aigus très fin et détaillé - de l'air ! - le medium à peine moins bon que les deux extrêmes pour l'instant...
Le contexte: ampli pas rodé, auditeur habitué aux tubes ( qui restent, à ce stade, plus à mon gout, sur le médium uniquement, car pour les extrémités du spectre c'est du très très qualitatif !); les enceintes ont deux modes,
Mode 1:des large-bande Phy-hp ( 21cm, bobine argent ) sur petit baffle plan avec en parallèle deux 38cm Yamaha dans 75 litres chacun filtrés par self de 3.8mH et un peu boosté en bas, obligé.
Mode 2: le même que le précédent avec un filtre actif numérique ( mini dsp ) qui le coupe à 780 Hz et relayé donc par ampli tubes (pp 6v6 schéma Dynaco ) qui alimente des compressions Altec 802D sur pavillon 811 avec en // à l’arrière une paire de compressions Yamaha sur petit pavillon Guigue filtrées par 1 microF orientées vers le haut, à l’arrière du pavillon 811 donc. Le mode 2 est donc une bi-amplification 3 voies et demi, actif/passif.
Ca matche parfaitement, cet Amp25 fait le job jusqu'à 780Hz et la transition ne se fait pas sentir..... Si le medium s'adoucit avec le rodage ça va être terrible en mode 1 ( large-bande ) ! Je reviendrais poster un avis plus tard, merci à Audiophonics d'avoir choisi d'importer ce petit bijou.
Pas testé le bluetooth...
SUPERBE SUR ENCEINTES HAUT RENDEMENT
Ayant déjà posté un avis relativement élogieux sur ce petit ampli énigmatique, j'ai effectué d'autres essais, cette fois sur enceintes Elipson p3i de rendement élevé (93.5db) et le résultat est parfaitement satisfaisant, enthousiasmant même! Les différents registres sont désormais très bien intégrés avec une définition ciselée sut tout le spectre. La dynamique enthousiasme par sa vivacité ce qui me fait songer à une technologie de classe D où seulement l'étage de sortie possèderait des Mosfet (hélas le fabricant est très avare d'informations ou de clichés de l'intérieur du petit prodige). Quoi qu'il en soit, les timbres sont remarquables de vérité au point que je crois ne pas avoir entendu quelque chose d'aussi bon avec quantité d'amplis analogiques que j'ai possédé. L'image stéréo profite d'une très bonne transparence pour se développer avec aisance, sans voile ni réduction rédhibitoire. Si vous voulez un conseil: ne vous ruinez plus avec les amplificateurs, optez pour ce petit amp25 et offrez vous des enceintes d'un bon rendement, disons 92 db ou un peu au dessus.
ETONNANT!
Les Chinois seraient ils devenus les maîtres incontestés de la musicalité? C'est bien possible si on se réfère à quelques produits phares, et ce minuscule amplificateur pourrait, dans la mesure de son prix modeste, se rajouter à la liste. Difficile de savoir exactement la technologie développée à l'intérieur de ce modeste mais très esthétique boîtier. est ce une classe AB pure? aucun orifice d'aération et le fait que l'ampli ne chauffe pas me fait penser à une technologie hybride numérique-analogique. Quoi qu'il en soit, cet appareil se distingue par son suivi mélodique remarquable et son excellente définition des registres aigu et médium d'autant que cette résolution ne s'accompagne d'aucune brillance artificielle. La transparence est bonne pour un classe AB même si elle n'atteint pas celle d'un petit FDA. L'image stéréo se situe plutôt au premier plan avec beaucoup de présence mais une profondeur d'image tout de même assez limitée dans l'absolu. Cet ampli, énergique mais modeste en puissance, montre tout de même quelques limites lorsqu'il s'agit de reproduire les grandes masses orchestrales ou un grand piano de concert. Dans les registres les plus graves, le son devient un peu compact au détriment bien sûr de l'intelligibilité du message, alors que l'image stéréo perd un peu de sa stabilité avec ici ou là quelques effets de projection, Il faut préciser que ces tests ont été faits avec des enceintes assez exigeantes dont le rendement est assez moyen (Cabassse Jersey MT32 à 89 dB), En conclusion, cet appareil fait merveille dans la restitution des petits ensembles (type chambristes, jazz ou vocal), mais est un peu à la peine avec le symphonique, on prendra soin de l'associer à des enceintes de rendement au moins égal à 90 dB. Compte tenu de son coût des plus modestes, le rapport qualité/prix est excellent.
This small integrated amplifier AMP25 in Class AB is an affordable, high-performance and stylish solution. Its MOSFET-based amplification stage is...
