ARMATURE PHOBOS AB Amplifier USB DAC 24bit/192khz
ARMATURE PHOBOS Amplificateur DAC USB 24bit/192khz
The PHOBOS armature amplifier fits in with its time. Featuring a generous power stage with a high current capacity Phobos faces the most complex loads.
By buying this product you get 139 loyalty points
11957
1 399,00 €tax incl.
1 165,83 € tax excl.
Available
Shipping date: 22-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Armature Phobos
Armature Audio Phobos
Symmetrical XLR / DAC amplifier 24bits 192kHz Armature Phobos
Power and control
The PHOBOS armature amplifier fits in with its time. Featuring a generous power stage with a high current capacity Phobos faces the most complex loads. High-performance loudspeaker enthusiasts or faithful studio monitor libraries, Phobos is the answer with a large number of analog and digital inputs.
Armature Phobos
Qobuzissime for the ARMATURE PHOBOS
Discover the complete and detailed test of the PHOBOS amplifier, which has been awarded a Qobuzissime for its quality and high performance (click on the banner below).
Qobuzissime Armature Phobos
A true digital HUB of 2x130W under 8 Ohm
The PHOBOS Audio Armature is the aliasing of digital and analog. It has a 24 bit 192kHz DAC with USB input CMEDIA, SPDIF coaxial, BNC, optical and 3 analog inputs including a balanced XLR input. It also has a variable pre-out output and a fixed DAC-out output.
The Phobos amplifier meets all operating scenarios. Armature Phobos
Armature Phobos
A genuine DAC 24bit 192kHz
The central card of the phobos includes a DAC Ti PCM1794 ensuring true digital analog conversion work of quality. Featuring a symmetrical dedicated power supply with a filtering capacity of 52800μF to 35V, a jitter bucker SRC4392, four LDO regulators and analogue output AOP LT1028, the Phobos DAC concentrates the best of technology in a single device .
A real comfort of use.
Thoughtfully, the Phobos remote control allows full control with pre-out, or an integrated amplifier mode, or both simultaneously. The PHOTO's DOT Matrix LED display provides real legibility without the aggressiveness of the main functions of the amplifier.
Armature Phobos
Armature Phobos
Connectors: Digital Inputs
RCA SPDIF1x
BNC SPDIF1x
Optical Toslink1x
USB 2.01x
Connectors: Analog Inputs RCA Stereo3x
XLR Symmetry1x
Connectors: Outputs
Pre Out-
Line Outputs DAC Line-
Signal Ratio> 115dB
THD0.004%
Frequency Response20Hz - 70kHz (at -3dB)
Output Impedance1 k ohms
Max Output Level2.5V (RCA) / 4.5 XLR Symmetrical
Input sensitivity0.5Vp-p (Coaxial, 75Ω) / 19dBm (Optical)
24-bit sampling
USB44.1kHz up to 384kHz and DSD 256x5
Coaxial44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz, DSD 64
Optical44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz, DSD 64
Miscellaneous
Dimensions425 x 325 x 105mm
chassis100% Aluminum
Weight18.6kg
AccessoriesPower cord, aluminum remote control
ComponentPCM1794
MaterialAluminium
ColorNoir
StructureAluminium
Channel2 channels (Stéréo)
InputXLR
Colissimo - TNT - SoColissimo
Puissance et lisibilité
L'essai publié dans Qobuz avec un Qobuzissime m'a fait craquer. En duo avec mes enceintes Cabasse Iroise 3, la combinaison est remarquable. A recommander sans réserve.
This review has been posted for ARMATURE PHOBOS AB Amplifier USB DAC 24bit/192khz
The PHOBOS armature amplifier fits in with its time. Featuring a generous power stage with a high current capacity Phobos faces the most complex...
