AUDIO-GD MASTER 10 BYPASS PREAMP Class-A Balanced Amplifier ACSS 2x 250W / 8 Ohm with Preamplifier Bypass
The Audio-GD Master-10 is an impressive, symmetrical Class A amplifier that delivers great power to accompany the most demanding lousdspeakers. In this version, the Master-10 offers a bypass input group preamplifier to take advantage of an external preamplifier to transform the Master in pure power amplifier.
KEY FEATURES :
  • Amplificateur intégré
  • Class A
  • Symmetricall
  • ACSS
  • 2 x 250W 8 Ohms / 2 x 500W 4 Ohms
  • Preamplifier Bypass
By buying this product you get 227 loyalty points
12438
2 279,00 €tax incl.
1 899,17 € tax excl.
Available
Shipping date: 22-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
AUDIO-GD MASTER-10 Edition 2015
Integrated Amplifier / Class A Symmetrical ACSS / Preamplifier Bypass
Audio-GD Master 10 edition 2015
An integrated amplifier of high power ...
Audio-GD introduces us once again to the quintessence of the audio technology with this MASTER-10 amplifier with more than neat and clean architecture.
The famous brand of high-fidelity audio offers here an amplifier in the most accomplished form possible with outstanding performance: it delivers 2x 250W under 8 Ohm, and 2x 500W under 4 Ohm.
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzer 2700 Series from Audio Precision.
A MASTER-10 with Preamplifier Bypass
The MASTER-10 offers a complete system with preamplification and amplification. In addition, for those who would like to take advantage of an external preamplifier, Audio-GD includes in this version a Bypass Pre-Amplifier input group, making it possible not to use the preamplifier section. Only the amplifier power part function In this way, you can benefit from an extremely flexible system. It's especialy made for Home theater system to.
Extremely efficient clean connections
The MASTER-10 has 5 analog inputs: 2x RCA / 2x XLR / 1x ACSS. The output is of course on 2 HP terminals, where you just have to connect your speakers to enjoy.
The result is unmatched: great musicality, thanks to an exceptional dynamic and a rich sound extremely detailed in all points. You can tell you that you are approaching - see attPerfect with this HiFi device.
audio-gd master 10 edition 2015
An unusual amplifier
Class A Symmetric / R-Core / ACSS / Integrated
This MASTER-10 is equipped with no less than 4 transformers including 2 R-Core for a total of 1500W, 140,000uF of very high-end Nover capacitors, and 24 very high performance MJL1302 / 3281 transistors for the output stage .
This amplifier is also designed around a purely symmetrical discrete circuit of Class A ACSS, with separate power supply to avoid any interference or electromagnetic disturbances on the signal.
ACSS
Audio-GD has its own technology signature called ACSS for "Audio-GD Current System Signal". Thanks to the firm's expertise and know-how, this technology offers a less colorful, detailed soundt unparalleled neutrality.
Every professional engineer of the brand is, in addition to being experienced, a passionate of HiFi and Audio like you and us. That is, when the ACSS output is used, the XLR and RCA outputs go to MUTE.
Class A
A class A amplifier has the particularity of having all its active components always in conduction. They fully amplify the input signal, thereby limiting harmonic distortion on the output signal. The outgoing signal of the Master-10 is therefore of excellent quality, due to the absence of this famous distortion of crossing of the alternations of the sinusoids.
Signal Noise ratio> 115dB
Voltage Ouput58V
Sensibility voltage input0.775Vrms (RCA) / 1.55Vrms (XLR) / 2mA rms (ACSS)
Frequency Reponse20Hz - 20kHz (0.01dB)
Ouptut2x Binding post output for loudspeakers
input2x RCA
2x XLR
1x ACSS
Input impedance47KΩ (RCA) / 94KΩ (XLR) / < 10Ω (ACSS)
Crosstalk> -120dB
Power Output2x250W  8Ω / 2x500W  4Ω
Preamplifier bypass Yes
Divers
Consumption130W
Power supply device4 Transformers with 2 R-Core for 1600W
WeightEnviron 40kg
Enclsoure material100% Aluminium
ColorNoir
Dimensions480 x 440 x 190mm
AccessorysMetal remote and IEC power cord
MaterialAluminium
ColorNoir
StructureAluminium
Channel2 channels (Stéréo)
ClassClass A / AB
Puissance Totale500-550 Watts
Colissimo - TNT - SoColissimo
The Audio-GD Master-10 is an impressive, symmetrical Class A amplifier that delivers great power to accompany the most demanding lousdspeakers. In...
