AUDIOPHONICS MOS-120 Amplifier Class A/B 2x120W / 4 Ohm Black
AUDIOPHONICS Amplifier Class AB LM3886 2x120W / 8 Ohm
4.8 / 5
Reference : 13085
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
MOS-120 discrete integrated amplifier
Amplifier 2x120W @ 4 Ohm / Volume Control / MOSFET IRFP240 & IRFP9240
Amplifier power mosfet
This integrated amplifier is inspired by PASS circuits and operates two high power MOSFET IRFP240 / IRFP9240. Its power stage offers massive power and detailed sound reproduction. Low frequencies are deep and emphasize the soundstage. Ideal for bringing thick and precise sound to a large room.
Ab class amplifier transistor
Discrete input stage transistors
The design of the input stage involves only discrete components. The signal goes symmetrically through a structure based on pairs of complementary transistors.
It is designed from paired transistors and arranged in a symmetrical structure. The models used are A42 and A92 transistors, capable of withstanding high voltages before distorting the sound.
This configuration limits any bias current before the power stage Class AB, which significantly limit the distortion.
Three integrated levels of protection
The device is equipped with an OMRON relay (switch delay) which ensures effective protection against unwanted noise (crunches and thumps) during power on and power off.
There is also a UPC1237 protection (protection amplifying stage & loudspeakers on each channel with overload detection) / a DC protection and a rectifier bridge at very low resistance.
OMRON amplifier protection
Class AB linear amplifier alim
Linear power supply
To match the specifications of the input stages and amplifier, this amplifier has a linear regulated power supply with a very effective design. This will directly affect the overall sound precision of the amplifier.
This power supply is operating with a diode bridge 50A (Japan Sanken) selected for its very low internal resistance.
50V capacitors 10000uF complement the power stage.
Toroidal transformer
The power stage operates through a 300VA toroidal transformer with impressive size.
The latter is maintained on the casing by an anti-vibration stabilizer seal.
In order to prevent electromagnetic interference and noise that may affect the signal quality, the transformer is insulated from the rest of the circuit by the internal radiator.
Slightly noticeable noise from the toroidal transformer.
Cheap power amplifier toroidal transformer
Amp MOSFET, transistors, power
Power amplifier stage
The AB class power amplifying stage uses complementary transistors C5171 and A1930.
All elements of the power stage arevented and  mounted on a large radiator to dissipate heat efficiently and to gain power without degrading the sound / prematurely wear the equipment.
Parts supplied
Amplifier 2x120Wx1
Characteristics
TypeIntegrated amplifier
Volume ControlYes
Source selectorNot
THD<0.02%
Power2x 120W 4ohm
Frequency response10Hz - 40kHz
SNR95dB
InputsRCA
OutputsSpeaker cable socket
Power supply220V AC 50Hz
Dimensions190 x 70 x 311 mm
Weight5.3 kg
Power cableNot inclued
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipA1930
Amplifier chipC5171
Power (W)120.0
31 reviews
Très bon produit
Acheté pour un second système, c’est un très bon ampli, bien fabriqué et aux qualités musicales réelles.
This review has been posted for AUDIOPHONICS MOS-120 Amplifier Class A/B 2x120W / 4 Ohm Black
Très surpris en bien
Je mis attendais pas a une présentation du son pareille. Plein de détail mais pas fatigant. Bravo!
Upgrade
Ik heb 5 van deze versterkers gekocht om een actieve home cinema set op te zetten door middel diy luidsprekers. Hoewel ik zeer tevreden ben over de geluidskwaliteit heb ik een tweak uitgevoerd door alle elektrolytische condensatoren te overbruggen met een kleine film condensator van Panasonic omdat ik die hier toch op voorraad had. En ik heb ook de ingang condensators vervangen. Ik dacht dat dit nauwelijks iets zou opleveren maar toen ik naar een vergelijkende test luisterde viel mijn mond open van verbazing. Vooral in het midden en hoog is er net een grote waas verdwenen. Stemmen hebben veel meer detail en het hoog is volledig opgehelderd. Ik heb dit getest met mijn achtergrond luidsprekers die bestaan uit een full range luidspreker zonder filter en in omnidirectionele opstelling. Het resultaat is gewoon geweldig! Ik heb nu een 150 van die condensator bijbesteld. Per versterker is de kost voor 9 stuks van 1uF en 2 stuks van 2,2 uF ongeveer 10 Euro. Echt aan te bevelen!
Simple, clear and powerful presentation of any music
I’ve got what I wanted. This classical AB Class amplifier design is capable of driving any loudspeaker system in a room with great sound and enough dynamics. This is what makes it different from a T-Class switching amp nowadays. There is no limitation on whatever classical, jazz, rock, or electric music is played. I really enjoy the performance and the sound quality. I don’t see any noise issue or vibration due to the big toroid transformer. The build quality is also excellent!
Improved version
It would be nice to be able to buy an improved version of this amp with better components so that I don't have to solder and throw away the replacement parts myself.
