By buying this product you get 38 loyalty points
Amplifier WiFi DLNA AirPlay2 Bluetooth 5.0 2x275W 4 Ohm
Note: This product offers many features, only its design with integrated DSP does not offer the transparency sought by audiophiles. The analog input also goes through the DSP via an ADC. We want this for someone who is looking for a network amplifier that supports many music services and protocols with comfortable power, but without the pursuit of high fidelity.
The CloudyX CL-300W A98 is a powerful and versatile integrated amplifier with advanced connectivity including Bluetooth 5.0 and WiFi integration. The device also features a phono (MM) input, which is handy for enjoying your vinyl records.
1 | Screen |
2 | Volume / Function button |
3 | Microphone antenna |
4 | Pairing / Reset switch |
5 | RJ45 (LAN) input |
6 | Optical Toslink input |
7 | HDMI input |
8 | USB-A input |
9 | Stereo RCA input |
10 | Phono MM input |
11 | Stereo RCA output |
12 | Subwoofer output |
13 | Optical Toslink output |
14 | Right channel speaker terminals |
15 | Left channel speaker terminals |
16 | Power supply connector |
17 | Power button |
18 | Bluetooth & WiFi antenna |
The CL-300W features an RCA phono (MM) input, allowing a vinyl turntable to be connected to it. This input is combined with an RIAA phono preamplifier that can restore the timbre of the original vinyl recording for a rich and detailed musical experience.
At the heart of the CloudyX CL-300W's amplification stage is a TPA3255 chip. It benefits from a Class D architecture and delivers a significant power of 2x 275W at 4Ω, with a high efficiency. In addition, this chip integrates a feedback system and the proprietary PurePath Ultra HD technology. The latter enables extremely low distortion across the entire bandwidth, while providing superior sound quality.
The CL-300W will allow you to easily set up a multiroom system to enjoy your music in all your rooms. Playback control is simple with the Muzo control application, available free of charge on Android and iOS. In addition, it will allow you to enjoy your favorite streaming services such as Qobuz, Spotify or Deezer.
The CL-300W is also compatible with Amazon Alexa, allowing voice control of playback and multiroom.
Product type | Amplifier |
Power | 2x 275W @ 4Ω 2x 150W @ 8Ω |
Inputs | WiFi 2.4G / 5G Bluetooth 5.0 1x Phono (MM) RCA input 1x USB-A Host 1x HDMI 1x Optical Toslink 1x RJ45 1x Stereo RCA Mic reception |
Outputs | 1x Stereo RCA 1x RCA subwoofer output 1x Optical Toslink Speaker terminals |
Frequency response | 20Hz - 20kHz |
THD | 0.05% |
Impedance | 2kΩ |
SNR | 95dB |
AUX Input sensitivity | 1V |
Phono input sensitivity | 5mV |
RCA output level | 1V |
Supported WiFi protocols | DLNA AirPlay2 |
Supported streaming services | iHeartRadio Spotify Tidal Napster Qobuz Deezer |
Mobile app | iOS / Android compatible |
Supported sampling rates | PCM up to 24bit 192kHz |
Multiroom | LinkPlay MRM / Amazon MRM compatible |
Supported HDMI technology | ARC |
Power supply | 100-240V |
Dimensions | 28 x 23 x 6cm |
Weight | 1.5kg |
Color | Black |
Package | 1x CloudyX CL-300W A98 1x Power cable 1x Remote control |
Input | Optical |
Input | RJ45 |
Input | WiFi |
Input | RCA |
Input | Bluetooth |
Input | HDMI |
Input | USB |
Output | Speaker terminal |
Output | RCA |
Output | Subwoofer |
Output | Optical Toslink |
DAC / ADC Chip | NC |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 275.0 |
