DAYTON AUDIO APA150 Class A/B Amplifier 150W 8 Ohm Black
DAYTON AUDIO Class A/B Amplifier 2x70 watts 4 Ohm Black
The DAYTON AUDIO APA150 from 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it offers a real solution that is very easy to use with a stereo input.
Reference : 12601
157,50 €tax excl.
Available
Shipping date: 27-06-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Caution: The product is delivered configured in 110V. If your electrical network supplies 220V (Europe), it is imperative to configure the device in 220V using the switch on the back of the device.
Dayton Audio APA150
Amplifier Class A/B - 1x150W 8 Ohm - 2x75W 4 Ohm
Dayton Audio APA150 Amplificateur de bureau Class A/B 1x150W 8 Ohm 2x75W 4 Ohm
High fidelity and power
The Dayton Audio APA150 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it brings a real solution of great ease of use with a stereo input, a power button and a volume on the front. It thus brings for a soothed budget, the capacity to control speakers libraries and speakers columns of quality.
Dayton Audio APA150
HIFI quality design
The Dayton Audio APA150 has an "old fashioned" design with discrete transistor components on its path with a toroidal transformer for realistic dynamics. Its refined design allows it to produce a particularly attractive and musical sound for an affordable budget of a disconcerting ease of use.
Mono mode and adjustable active filter
The Dayton Audio APA150 has an active filter adjustable from 50Hz to 150Hz allowing it to be transformed into an amplifier for subwoofer. The mono mode button allows 150w on one channel to drive a single bass speaker for example. The amp has a 15-minute auto sleep mode that can be disengaged.
Dayton Audio APA150
Dayton Audio APA150 review by Qobuz
" The Dayton Audio APA150 amplifier is a serious device that keeps its appearance and sound reproduction from being blurred, powerful and well-structured at the bottom of the spectrum, and benefits from a clever technical design. "
Test Qobuz
Review and measurements of the Dayton Audio APA150 by Audio Science Review
The Dayton Audio APA 150 performs along the lines that we have sunk into in budget amplifiers. No doubt with good speakers and content, the APA 150 will provide an enjoyable experience. "
Test et mesures du Aune X1s 10th Anniversary par Audio Science Review
ClassA/B
Stereo output power2x75W 4 Ohm
Mono output power1x150W 8 Ohm
Inputx1 RCA
OutputSpeaker terminal
Input impedance47 KOhms
Power supply110V or 230V (Adjustable switch)
SNR100dB
Active adjustable filter50Hz - 150Hz
Weight6kg
Dimensions170 x 174 x 392mm
MaterialMetal
StructureAluminium
Channel2 channels (Stereo)
ClassClass A / AB
Total Power (W)50-100
Power (max)150W
Colissimo - TNT - SoColissimo
The DAYTON AUDIO APA150 from 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it offers a...
