FX-AUDIO FX1002A TDA7498E Class D Amplifier 2x100W / 4 Ohm Black
FX AUDIO FX1002A TDA7498E Class D Amplifier 2x80 watts 4 Ohms
The FXAUDIO FX1002A 2x100W on 4 Ohm is the perfect high power integrated amplifier in a small aluminum housing. Powerful thanks to the latest generation Texas TDA7498E chip, it brings a real solution of great simplicity of use with a stereo input, a power button and a front volume. It thus provides the ability to drive even the most difficult bookshelf or column speakers for a reduced budget.
4.2 / 5
Reference : 12171
79,00 €tax incl.
65,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
FX-Audio FX1002A
Amplifier Class D 2x100W 4 Ohm
FX-Audio FX1002A Amplificateur de bureau Class D 2x152W 4 Ohm
High Fidelity and power
An audiophile quality design
The FX AUDIO FX1002A features audiophile level refinements and components including Epcos film capacitors. The double mono preamplifier part has three high quality interchangeable DIP 8 AOPs. The TL082CP DUAL JFET AOPs with fast and high bandwidth ensure transparency and dynamics.
Rear facade: inputs and output
1RCA input
2Right speaker output
3Left speaker output
4Power supply input DC 24-36V
FX-Audio FX1002A
Setting the gain by DIP selector
The gain of the FX-Audio FX1002A can be adjusted via a DIP switch located in its housing. The diagram opposite shows the different possible settings: 35.6dB, 33.1dB, 29.6dB, 23.6dB.
Test bench by Qobuz
The FX1002A has been fully tested by Qobuz. You can find detailed review by following this link.
SNR99dB
Max power4 Ohm @ THD 10% @ 32V : 2x125W
4 Ohm @ THD 0.1% @ 32V : 2x100W
8 Ohm @ THD 10% @ 32V : 2x60W
Power supplyDC 24-36V
Frequency response20Hz - 20kHz (-0.2dB)
Distortion0.10%
Inputs2x RCA
OutputsGold plated speaker terminals
Weight1.2kg
Dimensions165 x 95 x 30mm
Accessoris1x power cable
1x AC/DC switching adaptor 32V DC 5.9A
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTDA7498E
Power (W)125.0
23 reviews
Souffle, même potentiomètre à 0
J'ai déjà fais des commentaires favorable en terme de musicalité de cet ampli.
Je modérerais mes propos, pas sur la musicalité, mais sur un critère sur lequel j'étais persuadé pouvoir intervenir, le souffle, à savoir que le gain modifiable de cette ampli 23,6/29,6/33,1/35,6 est réglé d'usine au minimum, donc inutile de chercher de ce côté, le potentiomètre à zéro diminue ce souffle, mais il est reste toujours présent.
Le potentiomètre réglé pour l'instant à "midi" sur les amplis des médiums et celui des aigus est le seul compromis que j'ai trouvé.Les ampli, soufflent toujours moins que potentiomètre au max, mais il faut savoir que ces amplificateurs, soufflent. je précise, avec ou sans entré dessus, donc ce qui mets hors jeu le préampli ou le DSP raccordé dessus.
This review has been posted for FX-AUDIO FX1002A TDA7498E Class D Amplifier 2x100W / 4 Ohm Black
Excellent amplificateur
J'ai des enceintes trois voies que je faisait fonctionner en bi-amplification, un FX-Audio FX1002A drivait deux graves Fostex de 20cm et un amplificateur Single Ended à base de deux tubes 6L6GT drivait le couple Fostex/Audax en médium/aigu.
Ayant fait récemment l'acquisition d'une DSP Dayton DSP408 et ayant pu en apprécier toutes le qualités, j'ai décidé de faire évoluer mon système vers la tri-amplification.
Dans un premier temps, j'ai gardé la même configuration mais j'ai remplacé l'ampli à tubes par un FX1002A histoire de voire si ces amplificateurs classe D étaient fidèles à la réputation qui leur collait à la peau, c'est à dire peu musicale et dur dans le haut du spectre.
Objectivement, il n'en n'est rien, le FX 1002A soutient sans problème la comparaison avec l'ampli à tube, ,aucune dureté et manque de musicalité, de plus les 2x60W du FX-Audio donne de l'aisance et d'absence de saturation dans les pointes de niveau, les deux fois 5 W de l'ampli à tubes largement suffisent avec des HP de 93db de sensibilité et à régime normal, mais dès que le niveau augmente et atteint un côté certes déraisonnable, il marquent leur limite.
Cette première étape m'a motivé et poussé à faire l'acquisition d'un troisième FX1002A pour driver mes tweeter.
J'en suis actuellement à la suppression des filtres passif et au recâblage du tout.
Mais ces amplificateurs FX-Audio peuvent en remontrer à beaucoup d'ampli "dit" haut de gamme, j'affirme qu'il peuvent sans problème soutenir la comparaison contre des amplis à tubes ou à transistor les plus chers, compact, pas cher je recommande sans souci cet ampli.
Son seul handicape......................son prix qui aux yeux de certains "audiophiles" le place dans les pas assez cher.............................
Beau son
Après un souci de gros bruit de fond retour au service après vente.Deception.
Un nouvel appareil quelques jours plus tard et bonheur!
Super petit ampli utilisé en actif sur les compressions de deux 15pouces Tannoy.
Tres dynamique et fin pour un prix super.
Merci au service après vente pour son ecoute.
I am happy
SAV
Merci à l'équipe audiophonics pour son SAV qui me reprend sans soucis cet ampli défectueux.
(confirmé pour ma part dans le cadre de 1ères tentatives de classe D par l’utilisation d'un TDA-S50)
Siflement
Un sifflement est audible et très gênant en l'absence de son, il est couvert par la musique lorsque cela joue mais cela est pour moi insupportable et bien loin des avis ou essais présentés (Qobuz, catalogue commercial ?!!).
En tous cas je suis bien déçu.
Encore une ou 2 tentatives et j'abandonnerais la classe D qui semble très bien pour du MP3 sur enceinte bluetooth mais certainement pas pour de la HIFI.
Accessoirement, la puissance réelle semble être assez limitée (l'ampli était pour piloter un boomer de 21cm de 50w en multiamplification avec un ampli à tube el34 de 40w pour le médium - aigue).... Le FX devait jouer "au max" pour être au niveau du médium aigue à peine au quart de la puissance du push-pull el34... (rendement 90db pour le boomer, 91 pour le médium et l'aigue). Et ce alors que les branchement des transfo de sortie sont cablés en 4ohm pour du 8ohm... Puissance des el34 de l'ordre de 20/25w !!!
Bref, c'est un ampli de 10w sur 8hm qui siffle !.. Pas mieux que de la classe AB pour le poids !
Ce sifflement est anormal.
Si vous avez essayé une autre source et une autre connectique, contactez le SAV.
The FXAUDIO FX1002A 2x100W on 4 Ohm is the perfect high power integrated amplifier in a small aluminum housing. Powerful thanks to the latest...
