By buying this product you get 31 loyalty points
Pro Wireless Wall-Mount MultiRoom Stereo Amplifier 2X40W 8 Ohm
The iEast AMP-i50B is a small Class D amplifier with the particularity to integrate a complete network connectivity, allowing you to simply stream your music remotely from a device connected to the same network (smartphone, computer, NAS...) or from a compatible streaming service. The amplifier can also work in a multi-room environment, allowing you to sound several rooms in your home and control their playback via a dedicated application.
The on-board amplifier is capable of delivering a power of 2x40W at 8Ω with a high efficiency, above 90%, inherent to Class D. A digital DSP allows an efficient processing of the audio signal, ensuring a musical resititution with low distortion and high current capacity. Integrated in a metal housing, the heat of the components is efficiently dissipated thanks to adapted heat sinks. Another special feature of the AMP-i50B is that it can be mounted on a wall, which is particularly convenient for integration in a multi-room system.
The AMP-i50B therefore benefits from a particularly comprehensive connectivity and connectivity. WiFi and Bluetooth will allow you to broadcast your music remotely in an extremely simple way. The device also has a Micro SD slot, a USB-A port (for storage devices), an RJ45 connector and a 3.5mm jack line input. An RS232 serial port is also available in 3.5mm jack format. Finally, it is possible to remote the infrared receiver according to your installation.
Control is simple and intuitive from the dedicated iEast Play application, available free of charge for Android and iOS devices.
The AMP-I50B is compatible with many streaming services, allowing you to easily stream your music from any of them: Spotify, Qobuz, Deezer, Tidal, Tune In...
Product type | Amplifier |
Amplification type | Class D |
Power | 40W @ 24V, 6Ω, THD 0.7% 20W @ 24V, 6Ω, THD 0.06% 30W @ 24V, 8Ω, THD 0.4% 20W @ 24V, 8Ω, THD 0.12% |
Inputs | Micro SD USB-A Line input Jack 3.5mm Serial port RS232 via Jack 3.5mm WiFi 802.11 b/g/n Ethernet RJ45 10/100Mbit Bluetooth 4.0 |
Output | Speaker terminals |
Streaming services | Spotify, Qobuz, Deezer, Tidal, Tune In, iHeartRadio, Pandora, Napster, radios internet, QQ Music... |
Wireless protocols | DLNA UpNP Spotify Connect AirPlay QPlay |
WPS Compatibility | |
WiFi Security | WPA WPA2 |
SNR | 86dB |
Frequency response | 20Hz - 20kHz (±3dB) |
Supported sampling rates | Up to 24bit 192kHz |
Supported file formats | MP3, AAC, AAC+, ALAC, FLAC, APE, WAV |
Control app | iEast Play |
Firmware 4.2.7709.27 | Deezer support Amazon Music support (US only) Streaming directly from the application Adjustment of bass and treble from application Adding predefined profiles Optimization of stability and reliability |
Power supply | 24VDC 3.3A |
Min/Max operating temperature | -5°C / 40°C |
Housing material | Metal |
Dimensions | 146 x 134 x 31mm |
Weight | 1.3kg |
Color | Black |
Package | 1x iEast AMP-i50B 1x WiFi antenna 1x Bluetooth antenna 1x IR receiver cable 1x IR remote control 1x Power supply 1x Power cable |
Input | Bluetooth |
Input | RJ45 |
Input | Micro SD |
Input | WiFi |
Output | Speaker terminal |
DAC / ADC Chip | NC |
Color | Black |
Amplifier chip | N/A |
