IEAST AMP-I50A Pro Wireless Wall Mount Multiroom Stereo Amplifier 2X40W 8 Ohm
iEast AMP-i50A Wireless Wall-Mount Multi-Room Stereo Amplifier 2X40W / 8 Ohm
The iEast AMP-i50A WiFi Class D amplifier delivering 2x40W power is relevant in many aspects. It can perform high fidelity multiroom audio functions of WiFi and Bluetooth 4.0 wireless reception on any pair of stereo speakers.
By buying this product you get 31 loyalty points
Reference : 11858
319,00 €tax incl.
265,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
iEast AMP-i50A
iEast AMP-i50A Amplificateur Professionnel Sans Fil Multiroom Mural 2x40W 8 Ohm
Particularly suitable for multi-room installations with its integrated wall mounting, the AMP-i50A is perfectly adapted to any type of indoor integration, thanks to its infrared offset and its central RS232 serial port compatibility.
Dedicated iOS and Android applications offer the easiest way to set up a wireless sound system in any room of your home. The apps offer the option of synchronized playback, which allows you to stream music to all rooms at the same time by chaining multiple AMP-i50A's together.
You can stream your music from your smartphone, a tablet, a streaming application (Spotify, Qobuz, Deezer, Tidal...), a NAS or a USB storage device.
Equipped with an advanced Class D digital DSP, this 2x40W stereo amplifier produces a pleasant musical sound with low distortion and high current capacity.
iEast AMP-i50A Amplificateur Professionnel Sans Fil Multiroom Mural 2x40W 8 Ohm iEast AMP-i50A Amplificateur Professionnel Sans Fil Multiroom Mural 2x40W 8 Ohm
iEast Play App
Control is simple and intuitive from the dedicated iEast Play application, available free of charge for Android and iOS devices.
Application iEast Play
Streaming services
The AMP-i50A is compatible with many streaming services, allowing you to easily stream your music from any of them: Spotify, Qobuz, Deezer, Tidal, Tune In...
Product typeAmplifier
Power2x5W @ 8Ω, 1kHz, 0.027%
2x32W @ 6Ω, 1kHz, 0.7%
2x40W @ 8Ω, 20Hz-20kHz, 5%
Wireless connectivityWiFi IEEE 802.11 b/g/n
Bluetooth 4.0
Inputs1x RJ45 (10/100Mbps)
1x USB-A Host
OutputsSpeaker terminals
Serial port Jack 3.5mm to RS232
Streaming protocolsDLNA
UPnP
Airplay
Spotify Connect
Tune In
QPlay
Material compatibilityiOS
Android
iTunes for Mac and PC
Streaming Services CompatibilitySpotify, Qobuz, Deezer, Tidal, Pandora, iHeartRadio, Rhapsody...
NAS compatibilityDLNA
Supported audio formatsMP3, WMA, AAC, AAC+, ALAC, FLAC, APE, WAV
Speakers impedance4-32Ω
Dynamic range> 87dB
SNR> 88dB
Stereo separation> 81.5dB (1kHz)
Frequency response20Hz - 20kHz (±3dB)
Operating temperature0°C / 40°C
Power supply24VDC 3.3A
Dimensions112 x 225 x 31.5mm
Weight1.3kg
Package1x AMP-i50A
2x WiFi Antenna
1x IR blaster cable
1x IR remote control
InputRJ45
InputMicro SD
InputWiFi
OutputSpeaker terminal
DAC / ADC ChipNC
Max sampling rateNC
Amplifier chipN/A
The iEast AMP-i50A WiFi Class D amplifier delivering 2x40W power is relevant in many aspects. It can perform high fidelity multiroom audio...
