SMSL AO200 Class D Amplifier 2x MA12070 Balanced Bluetooth 5.0 Subwoofer 2x90W 4 Ohm
30%
The SMSL AO200 is a compact and powerful Class D digital amplifier, capable of developing a power of 2x90W under 4Ω thanks to its two Infineon MA12070 amplifier chips. A power totally mastered in order to reveal a sound restitution of a great purity and dynamics.
Reduced price!
Reference : 15515
Limited special offer
289,00 €tax incl.
-30%
202,30 €tax incl.
168,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the new version, the SMSL AO200 Class D Amplifier MA5332MS.
SMSL AO200
SMSL AO200 Amplificateur Class D Symétrique 2x MA12070 Bluetooth 5.0 2x 90W 4 Ohm
The SMSL AO200 is a compact and powerful Class D digital amplifier, capable of developing a power of 2x90W under 4Ω thanks to its two Infineon MA12070 amplifier chips. A power totally mastered in order to reveal a sound restitution of a great purity and dynamics. Versatile, it benefits from both a balanced input, but also Bluetooth 5.0 reception and a Subwoofer output.
Balanced & Single-Ended
In order to integrate with all audio systems and to adapt to all needs, the SMSL AO200 is equipped with two inputs. There is an unbalanced input on RCA and a balanced input on XLR. Each connector is gold plated to ensure a very good conductivity and durability.
Subwoofer output
With the AO200 it is possible to set up a 2.1 audio system, thanks to an output on RCA connector. Ideal to reach deep and punchy bass.
Infineon MA12070
At the heart of the AO200's amplifier stage are two Infineon MA12070 Class D amplifier chips. These allow to offer a consequent power, associated with a high efficiency of 92%, a reduced consumption and then of course a sound of a great richness. These chips adopt the new MERUS architecture, totally different from a classic Class D architecture. Each half-bridge uses four MOSFETS (M1-M4) and a capacitor between them as an additional power rail to generate a three-level output signal at the output node.
Bluetooth 5.0
With its Bluetooth 5.0 receiver, the AO200 allows you to broadcast your music from a distance, directly from a smartphone for example. The 5.0 standard ensures a fast and stable transmission over a distance of 10m.
EQ Settings
The AO200 has 8 preset equalizers to suit your listening and your audio system. You can also manually adjust the bass and treble levels for fine tuning.
High-end components
The AO200's circuitry uses high quality components to provide the best possible performance. We can find a particularly precise and low distortion NJW1194 volume controller, EOP1678 AOPs, ERO capacitors or low noise MELF resistors.
An optimized power supply stage
The power supply stage is not to be outdone since it is based on a power supply module custom designed to provide an instantaneous power of 300W. It thus allows to favour a beautiful dynamic while limiting efficiently the impact of the interferences. For that it uses in particular a large transformer with low leakage and a filtering of the input at two levels.
1Multifunction knob
2IR Receiver
3Screen
4Single-ended RCA input
5Bluetooth antenna concector
6Right channel output
7Power supply connector
8Balanced XLR input
9Subwoofer output
10USB-A input
11Left channel output
12Power button
Product typeClass D Amplifier
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Bluetooth 5.0
1x USB-A
OutputsSpeaker terminals
1x Subwoofer (RCA)
THD+N0.003%
SNR110dB
Channel separation98dB
Input sensitivity280mV
Input impedance47kΩ
Output power2x 150W @ 2Ω
2x 90W @ 4Ω
2x 50W @ 8Ω
Supply voltage110-240VAC
ConsumptionNormal volume level: 40W
Standby: 0.5W
Dimensions187.5 x 154 x 40mm
Weight960g
SMSL AO200 Amplificateur Class D Symétrique 2x MA12070 Bluetooth 5.0 2x 90W 4 Ohm SMSL AO200 Amplificateur Class D Symétrique 2x MA12070 Bluetooth 5.0 2x 90W 4 Ohm SMSL AO200 Amplificateur Class D Symétrique 2x MA12070 Bluetooth 5.0 2x 90W 4 Ohm SMSL AO200 Amplificateur Class D Symétrique 2x MA12070 Bluetooth 5.0 2x 90W 4 Ohm SMSL AO200 Amplificateur Class D Symétrique 2x MA12070 Bluetooth 5.0 2x 90W 4 Ohm SMSL AO200 Amplificateur Class D Symétrique 2x MA12070 Bluetooth 5.0 2x 90W 4 Ohm
InputXLR
OutputSpeaker terminal
OutputSubwoofer
Channel2.1
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)90.0
3 reviews
Excellent
Branché à la place d'un ampli Marantz de 100w sur des enceintes de proximité je suis bluffé par la qualité de cet ampli.
Sur des enceintes à base de tweeter aurum quantus et grave fountek c'est de mon point vue au top.
Envoi très rapide, emballage correcte bravo Audiophonics
This review has been posted for SMSL AO200 Class D Amplifier 2x MA12070 Balanced Bluetooth 5.0 Subwoofer 2x90W 4 Ohm
Très bel ampli
J’ai cet ampli depuis pas mal de temps maintenant.
C’est tout d’abord un appareil très bien fini, avec un bouton principal agréable à utiliser, un écran extrêmement lisible et une télécommande qui fonctionne parfaitement bien.
En ce qui concerne l’audio, je l’utilise avec un lecteur réseau Raspberry + interface Allo Digione et fonctionnant sous Volumio et une alimentation dédiée Audiophonics.
Vient ensuite un DAC Topping D70.
Les enceintes sont des Focal Aria 906.
Et bien je trouve que jusqu’ici, c’est le meilleur « petit » ampli que j’ai eu.
Il est largement assez puissant, très précis, le bas est très agréablement retranscrit, les voix sont magnifiques.
Quand on fait le total financièrement, à peine plus de 2000.00€ y compris les câbles (tout l’ensemble vient de chez Audiophonics, hormis les enceintes), et bien je pense qu’il est très compliqué de trouver un ensemble aussi qualitatif que celui ci.
Encore un grand merci à Audiophonics pour sa disponibilité, ses conseils techniques, son service commercial.
Pascal
 (3)
Excellent ampli
Acheté en complément d'un Topping EX5, je suis pleinement satisfait de cet ampli. Plus aucun bruit parasite présents sur certains ampli A et même D. De nombreux paramètres, la luminosité de l'écran est configurable, il s'éteint même au bout d'une période à définir. Niveau puissance, rien à redire dans mon cas pour un usage sur pc avec 2 Wharfedale diamond 220 + un petit caisson yamaha yst-sw215. A noter que les basses dont d'une netteté rare bien meilleure que sur mes ampli hc (denon x2000 / yamaha rx-a780).
Excellent rapport Q/P, vous en aurez pour votre argent.
Le topping EX5 chauffe un peu donc je le laisse à un volume de 70-75% max et 20-40% max sur le AO200. Un couple parfait en les plaçant pas trop près car ils n'ont évidemment pas les mêmes formes et dimensions.
The SMSL AO200 is a compact and powerful Class D digital amplifier, capable of developing a power of 2x90W under 4Ω thanks to its two...
