TOPPING PA3 TDA7498E Class D Amplifier 2x80W 4 Ohm Black
TOPPING PA3 Class D amplifier 2x80 watts 4 Ohms
99,00 €tax incl.
82,50 € tax excl.
TOPPING PA3 class D 2x80W Black
- High Fidelity Desktop Amplifier -
topping PA3 2x80W 4 ohms
Compact and powerful
The Topping PA3 2X80W on 4 Ohm is the perfect built-in amplifier for a second system on his desk. Melodic and powerful thanks to a state of the art Texas TDA7498E chip, it provides a truly elegant and easy to use solution with two stereo inputs, a selector switch and front panel volume.
Intelligent monitoring control
The TDA7498E chip is supported by an MCU processor that avoids power surges, while the undervoltage overloads provide real protection for the speakers and loudspeakers connected to the PA3 Topping.
Audiophile quality components
The passive components of the PA3 Topping are first-class components using Nichicon capacitors known for their reliability and fidelity as well as Epcos plastic film capacitors at strategic locations on the pre-amplifier side. The potentiometer is a model of ALPS Japanese brand known worldwide for the seriousness of its achievements.
  • Rapport signal bruit : 90dB
  • Gain : 29.3dB
  • Sensibilité d'entrée : 0.6Vrms (4Ohms) 0.9Vrms (8Ohms)
  • Niveau de bruit : 0.5mV pondéré A
  • Puissance maximal : 2X70W 8Ohms, 2X80W 4Ohms
  • Distorsion par harmonique : 0.04%
  • Réponse en fréquence : 20Hz - 20kHz (-0.2dB)
Entrées :
  • 2x entrées RCA
Sorties :
  • Borniers haut parleurs plaqué Or
  • Poids : 515g
  • Dimensions : 168 x 120 x 37 mm
  • Accessoire : un cordon secteur, un adaptateur secteur
  • Couloir : Noir
Dimensions Topping PA3
Puissance Totale50-100 Watts
Colissimo - TNT - SoColissimo
