WONDOM AA-AC11134 Explorer Bluetooth 2.1 Amplifier Class D 2.1 2x 100W / 6 Ohm
Sure Inspiration Bluetooth 4.0 Audio Receiver w Aluminum Enclosure
Reference : 10055
149,00 €tax incl.
124,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Sure proposes here a Amplifier 2.1 Bluetooth 2.1 very versatile which delivers 2x 100W under 6 ohm.
It has an RCA output allowing you to power a pair of speakers and a subwoofer simultaneously.
With its compact design, stylish aluminum housing and ease of use, this 2.1 amplifier will allow you to listen to your favorite songs on your audio system in Bluetooth type Smartphone, Tablet, iPhone, iPad ...
Qobuz
This A2100 switching amplifier has been tested by Qobuz
Characteristics :
  • Amplifier TDA7498
  • Power: 2x 100W under 6 ohm (THD + N <1%)
  • Yield:> 90%
  • Inputs: RCA stereo, Optical TOSLINK (16bit 48kHz), line Jack 3.5mm
  • Hp terminal outputs for banana and RCA plugs for Subwoofer
  • Headphone Jack Jack 3.5mm
  • Frequency response: 20Hz - 22kHz
  • Signal Noise Ratio: 120 dB
  • LED status indicator
  • Volume control by turning the knob
  • Selecting the source by pressing and turning the knob
  • Wireless Audio Transmission via Bluetooth 2.1
  • Povercurrent and overheat protection
  • Power supply: 14 to 36V DC via DC jack
  • 24V DC 5A adapter supplied (Power cordNOdelivered, available as an accessory)
  • Remote control included
  • Chassis Aluminum
  • Black Anodized
  • Dimensions 210x124x48mm
3 reviews
PETIT BIJOU CONFIRMER
Voila, je confirme ce qu'a écrit Danie.B. Il y a bien un petit bouton sur la teleco en bas a gauche qui sert d'équaliseur , Je suis content, merci a toi Danie. C'est vrai c'est un petit bijou.Et merci a l'équipe D'audiophonique pour leur sérieux. @+
This review has been posted for WONDOM AA-AC11134 Explorer Bluetooth 2.1 Amplifier Class D 2.1 2x 100W / 6 Ohm
PETIT BIJOU
DANIE.B
J'ai fait l'acquisition d'un ampli SURE 2100 il y a à peu près 2 semaines. J'ai pris mon temps pour bien cerner l'utilisation de cet ampli en terme de fonction et qualité sonore. Au niveau de la télécommande, il semblerait ( dernier bouton à gauche ) qu'elle ait une fonction équaliseur numérique. Selon les appuis le son parait plus en retrait ou plus présent, avec plus de grave ou moins d'aigu. Une autre position se révèle plus linéaire, avec un équilibre sonore normal. C 'est cette position que j'ai retenu. Cet ampli entre dans la configuration suivante. Enceinte Q acoustic 1010 , caisson dôme Focal, Ampli Atoll in 30. Dac Magic plus , source multimédia WD. Comparativement à l'ampli cité plus haut, le Sure 2100 surprend par son côté chantant et naturel, le tout empreint d'une dynamique surprenante. Les voix dégagent beaucoup d'émotion. Le secteur aigu excelle en définition et réalisme ( cymbale, caisse claire, pincement de corde d'une guitare acoustique) . Quant au secteur grave il est profond et bien tenu. Cet ampli est surprenant et relègue mon Atoll au second plan, qui pourtant me satisfaisait pleinement. Que penser des amplis numériques ? Je pense que cette technologie est arrivée à maturité, offrant des rapports qualités prix stupéfiant.
Merci à Audiophonics de nous faire connaître ces petits bijoux.
LA BAFFE
Je me suis procurer une paire de JAMO S408 pour presque rien...Mais le problème c'est que j 'avais rien pour les tirer...Donc j 'ai vu cette petite bestiole 2x100 en 6 ohms. J 'ai penser que peu être ça pouvais les tirer (peut être)...Eh bien la je suis rester sur le cul (façon de parler). Tester en câble optique et ben croyez moi ou pas le commentaire des tests signalés est exact ...Poussé a fond avec les JAMO le samedi soir ils ont vibrer dans l immeuble. aucun problème de basse je pense pas rajouter de caisson de basse pour moi c est bon .N'écouter pas le commentaire sur YouTube ou un gars critique, c 'est un type qui a pas fait son teste. un novice aurait fait mieux que lui (blabla). La dessus je vais lui rajouter le FX-AUDIO TUBE-03 Préamplificateur à Tubes 6J1 Stéréo Argent pour l'entrée analogique pour rattraper deux potars grave , aigu. AUDIOPHONIC TRÈS TRÈS BON SITE N HÉSITEZ PAS...
