Service ups à chier audiophonie rien à dire
Ampli wiim exelent qualité ce marie très bien avec mes focal chora 806 et application très bien pour le moment
By buying this product you get 36 loyalty points
The WiiM Amp is an amplifier and streamer that's as compact as it is versatile and high-performance! It lets you distribute your music extremely simply via DLNA, AirPlay 2, Bluetooth (bidirectional) or Chromecast. So you can easily access your music library, whether it's stored on a computer, NAS or smartphone. What's more, control of the device and playback is made easy with the WiiM Home mobile app. The app also gives you access to your favorite streaming platforms, such as Spotify, Tidal, Deezer and Qobuz.
On the amplification side, we find a high-efficiency Class D circuit TPA3255, capable of developing a comfortable power of 2x100W into 4Ω or 2x60W into 8Ω.
To enable you to enjoy your music remotely, the WiiM Amp integrates a streamer. The connection can be made via WiFi or RJ45 Ethernet. DLNA, AirPlay 2, Spotify Connect and Chromecast transmission protocols are supported. So you can easily access all the music stored on your network, whether on a computer, NAS or smartphone. This connectivity also lets you enjoy your favorite music streaming applications.
Bluetooth 5.0 wireless connectivity is also available. Bi-directional, it lets you stream music from a smartphone, for example, but also pair the WiiM Amp with Bluetooth headphones or speakers.
Once connected, the WiiM Amp will give you access to numerous music streaming applications such as Spotify, Deezer, Tidal, Qobuz, Amazon Music, Apple Music and Napster. You can also enjoy webradios such as iHeartRadio and TuneIn.
The WiiM Amp's Class D amplifier TPA3255 stage enables it to develop 2x100W into 4Ω or 2x60W into 8Ω, and all with high efficiency. This makes it ideal for powering bookshelf speakers or small columns. What's more, its careful, optimized design enables the amplifier to deliver precise, dynamic sound reproduction. What's more, it's possible to adapt the sound of the device thanks to numerous predefined equalization profiles and a 10-band parametric equalizer.
Enjoy excellent sound quality with WiiM AMP. The combination of an ESS ES 9018K2M DAC and a TI TPA 3255 amplifier chip delivers excellent performance, with a THD+N of just 0.002% (-93dB) and an SNR of 98dB at 5W. The WiiM offers precise, detailed reproduction.
In addition to its wireless connectivity, the WiiM Amp offers a comprehensive range of connectors, enabling it to integrate with the vast majority of audio systems. Inputs include stereo RCA and Toslink optical, as well as HDMI ARC for connecting a TV, and USB-A for playing music from a storage device (USB key or hard disk). Output is via speaker terminals that accept banana plugs. The signal can also be distributed to a subwoofer via its subwoofer output.
| 1 | HDMI ARC input |
| 2 | Ethernet RJ45 plug |
| 3 | RCA input |
| 4 | Speaker outputs |
| 5 | Power input |
| 6 | USB-A plug (USB Host) |
| 7 | Optical Toslink input |
| 8 | Subwoofer output |
The WiiM Amp can be used as a stand-alone unit, or combined with other units in a multiroom system. This makes it possible to distribute music throughout the home from a centralized control point, via the WiiM Home mobile application. Playback and volume can then be managed either synchronously for all devices, or independently for each piece of equipment.
Multiple devices can be linked in multiroom mode with any compatible LinkPlay device, or with AVS Multiroom and AirPlay 2 technologies.
The ergonomic, intuitive WiiM Home application gives you remote control of your WiiM Amp and music playback. It's also the access point for compatible streaming services.
The device can also be used completely independently, thanks to the remote control.
Finally, the WiiM Amp is compatible with Google Assistant, Amazon Alexa and Siri voice assistants, the WiiM Amp can be controlled by voice by linking it to the connected speaker of one of these systems or by using the microphone built into the remote control.
The WiiM AMP is easy to control by voice, thanks to the included Bluetooth remote control with microphone and Alexa voice assistant. This means you can control music playback and volume levels in a perfectly intuitive way.
"The WiiM Amp is a very well executed streaming, multi-room amplifier. It easily plays against big boys of streaming despite lacking their name recognition. Objective performance is very good for the class."
| Specifications | |
| Product type | Amplifier and streamer |
| Amplification type | Class D TPA3255 |
| DAC chip | ESS SABRE ES9018K2M |
| Inputs | WiFi Bluetooth 1x Stereo RCA 1x Optical 1x HDMI ARC 1x USB-A 1x HDMI ARC 1x Ethernet RJ45 |
| Outputs | Speaker terminals 1x Subwoofer output |
| Output power | 2x60W @ 8Ω 2x100W @ 4Ω |
| Supported network protocols | AirPlay 2 DLNA Chromecast |
| Control app | WiiM Home |
| Compatible voice assistants | Amazon Alexa Google Assistant Siri |
| General | |
| Dimensions | 190*60*190mm |
| Color | Silver |
| Package | 1x WiiM Amp 1x Remote control 1x Power cable |
| Input | WiFi |
| Input | USB |
| Input | Optical |
| Input | RJ45 |
| Input | HDMI ARC |
| Input | RCA |
| Input | Bluetooth |
| Output | Speaker terminal |
| Output | Subwoofer |
| Color | Silver |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3255 |
| Power (W) | 100.0 |
| Remote Control | Yes |
| Remote Control | Control app |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
David S.
