HIDIZS MERMAID MS1 In-Ear Monitor IEM Dynamic Drivers 20Ω 112dB 20Hz-40kHz
Hidizs proposes with its in-ear earphones MS1 a powerful model and proposed at a contained price. It uses dynamic transducers with a diaphragm specially designed by the brand for a transparent and precise sound reproduction.
4.0 / 5
Reference : 16418
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Hidizs Mermaid MS1
Hidizs MS1 Écouteurs Intra-Auriculaires IEM Dynamiques 20Ω 112dB 20Hz-40kHz
10.2mm dynamic speakers
Like other IEMs of the brand, the MS1 is equipped with the brand new 10.2mm polymer bio-membrane dynamic driver, capable of providing an extended frequency response from 20Hz to 40kHz. In addition, the dual magnetic circuit and dual acoustic chamber allow for a beautiful soundstage and high accuracy.
Resin body for optimal comfort
The body of the MS1 is made of high-density German Makrolon resin. The very structure of the IEMs, based on a large amount of ergonomic data, ensures a comfortable fit even during long listening sessions.
Integrated Controls & Microphone
Practical, the cable of the MS1 integrates controls as well as a microphone. It is thus possible to control the playback of music but also to answer calls, without having to take your smartphone out of your pocket.
High density aluminum acoustic tube
To promote accurate sound reproduction, the MS1's sound tube is made of an aluminum alloy with gold plating, allowing every detail to be reproduced in perfect clarity.
Silver plated copper cable
The supplied cable consists of four silver-plated OFC copper conductors, ensuring optimal transmission of the audio signal.
Interchangeable cable
The cable is also interchangeable, plugging into the headphones on a 0.78mm 2-pin connector. It is thus possible to simply replace it with another model if needed.
Product typeIn-Ear Monitors (IEM)
DiaphragmPolymer
DriversDynamic drivers Ø10.2mm
Housing materialMakrolon Resin
Gold-plated aluminum alloy acoustic tube
Integrated controls and microphone
Frequency response20Hz - 40kHz
Sensitivity112dB
Impedance20Ω
Cable conductors4x Silver plated OFC Copper conductors
Cable length1.2m
IEM connectors0.78mm 2 pins
Gold plated
Cable input connectorGold palted Jack 3.5mm
Power handling10mW
Weight≈ 6g
PackageHidizs MS1
1x Single-ended cable with microphone
1x Transport bag
2x Eartips pairs
Impedance (Ω)20
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
Ecouteurs
Ecouteurs corrects, on sent bien les basses, aigus.
This review has been posted for HIDIZS MERMAID MS1 In-Ear Monitor IEM Dynamic Drivers 20Ω 112dB 20Hz-40kHz
Hidizs proposes with its in-ear earphones MS1 a powerful model and proposed at a contained price. It uses dynamic transducers with a diaphragm...
