IBASSO AM05 In-Ear Monitor IEM 32 Ohm 115dB 10Hz - 40kHz
iBasso's new in-ear earphones, the AM05, benefit from an intelligent design and an atypical sound and excellent listening comfort. The AM05 are the first models in the brand's All Music range.
By buying this product you get 25 loyalty points
Reference : 14374
259,00 €tax incl.
215,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
iBasso AM05
Écouteurs Intra-Auriculaires IEM 32Ω 115dB 10Hz - 40kHz
iBasso Écouteurs Intra-Auriculaires IEM 32Ω 115dB 10Hz - 40kHz
A perfect design
The AM05 are the first iBasso EMIs to be based solely on Knowles Balanced Armature transducers. Each earphone incorporates 5 of these drivers, renowned for their high sound quality.
The transducers have also been carefully adjusted by iBasso engineers using a filter specially developed for the AM05. This means that each transducer is responsible for reproducing a precise frequency range, allowing an incredible level of precision and richness of sound to be achieved.
EMI also uses a high quality film capacitor to limit the impact of electrical interference on the restitution. As a result, the level of distortion is reduced for a more transparent and pure sound.
iBasso Écouteurs Intra-Auriculaires IEM 32Ω 115dB 10Hz - 40kHz iBasso Écouteurs Intra-Auriculaires IEM 32Ω 115dB 10Hz - 40kHz
Silver plated Copper MMCX Cable
The headphones are delivered with a MMCX to 2.5mm balanced jack cable incorporating silver-plated OFC copper conductors, allowing excellent signal conductivity, while limiting interference and distortion. The cable is also detachable, and therefore replaceable by another model according to your needs. The earphones also come with a 2.5mm balanced to 3.5mm unbalanced TRS jack adapter.
Confort & Design
The body of the AM05 benefits from an atypical design since they are moulded in transparent resin, leaving the components of the earphones visible. If this design gives the EMI an original aesthetic, it has also been worked to adapt perfectly to the shape of the ear and the ear canal. In addition, the AM05s are delivered with several pairs of silicone ear tips in different sizes.
Product typeIEM
Speaker driver5x Knowles Balanced Armature
Frequency response10Hz - 40kHz
Sensitivity115dB (±2dB) @ 1kHz
Impedance32Ω
Passive noise reduction-30dB
Distortion level< 2% (@ 1kHz/1mW)
Cable typeMMCX (detachable)
Cable length1.2mm
Cable conductors materialSilver plated Copper
ConnectorsBalanced Jack 2.5mm
Jack 2.5mm to Jack 3.5mm TRS adapter included
Body materialResin
ColorTransparent and blue
PackageiBasso AM05
Silver plated OFC Copper MMCX cable
Balanced Jack 2.5mm to Jack 3.5mm TRS adapter
Metal protective case
13x Pairs of silicone eartips
2x Pairs of foam eartips
ColorTransparent
ColorBlue
Impedance (Ω)32
Efficiency / Sensitivity (dB)115.0
Lowest frequency (Hz)10
Highest frequency (Hz)40000
Pas déçu
Bonjour,
Couplé à un DX120 j'étais jusque là possesseur des IT04 qui ne sont malheureusement plus disponibles, je me suis trouvé dans l'obligation de les changer car l'intra gauche a lâché.
Il y a (pour mon oreille) une grosse différence, l'AM05 est beaucoup plus dynamique, moins feutré. La restitution est très claire, la spécialisation excellente mais Les basses sont plus ''sèches" et moins rondes.
Amateur de techno et autres styles basés sur les basses il n'est peut-être pas fait pour vous.
Petit truc, n'hésitez pas à essayer les différents embouts proposés, cela peut significativement changer la restitution finale.
Pour information j'écoute des styles très différents; Industriel, Rock Progressif, Métal, Rock, Blues, Classique...
Cordialement
This review has been posted for IBASSO AM05 In-Ear Monitor IEM 32 Ohm 115dB 10Hz - 40kHz
iBasso's new in-ear earphones, the AM05, benefit from an intelligent design and an atypical sound and excellent listening comfort. The AM05...
