iBasso IT01 In-ear monitor High definition Diaphragm 10mm 18 Ohm
iBasso IT01 Earphones
With its extremely fine construction and its original design which directly tackles audiophile exigeances, the IT01 in-ear monitors are a very pleasant device for enjoying rich sound anywhere.
4.9 / 5
Reference : 13041
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the new version, the Ibasso IT01X In-Ear monitors.
In-ear headphones IT01 iBasso
High Definition IEM
intra IT01
This model is interesting in itself since its design gives a central importance to magnetic flux management issues. A way to make the most of its in-house developed dynamic driver without spending excessive energy.
Perfectionist design
Intra IT01 ibasso dismantled
Although the construction is  fine enough to praise its space management (with the ergonomic advantage implied, IT-01 shine primarily by the quality of its electronic components.
Speaker dynamic custom developed
Earphone intra dynamic transducer IT01
Each channel has its dynamic Ø10mm transducer coupled to a Helmholtz resonator opening onto vent (bass-reflex).
The transducers were custom made to fit the exact specifications and the particular form-factor of these in-ear monitors. This greatly contributes to the excellent stability and dynamic finesse of rendering.
resonators Helmhotlz
bass reflex headphones
On each channel, the transducer is enhanced by a Helmholtz resonator opening onto vent (bass-reflex).
This design when used wisely in a rigorous construction, emphasizes the bass frequencies and reinforces the excellent frequency response ITE IT01.
The integration of this technology also reduces the mechanical stress on the motor, which allows a better definition of its dramatically reducing distortion.
diaphragm Graphene
Diaphragm intra headphones
The-ear headphones IT01 have a graphene membrane.
This material is ideal for outstanding lightness (comfort during long plays) as well as by its strength and durability.
audiophile cabling
Earphone removably detachable cable wire
To maintain the precision of the signal and to highlight the virtues of a player / amplifier nomadic quality, IT01 earphones come with a OFC copper cable handmade. The conductors are gold plated to maintain a stable and reliable signal between the transducer and the amplifier.
The cable is protected against twisting by a lightweight sheath which drastically reduces the weight of the connectors to avoid feeling tired or constriction that may alter the listening ease.
This translucent sheath leaves moreover appear quadruple yarn structure with a pleasant visual rendering.
Finally, this cable has been the subject of a microphone processing to significantly reduce the noise inherent in listening intra: movement / cable friction with clothes & hair, shocks, sway ... etc.
TypeIn-Ear Monitor
Frequency response10 Hz - 42 kHz
Sensitivity108 dB (± 2 dB)
Impedance16 Ω
max10mW
THD @ 1kHz 1mW<1%
Insulation26 dB
Transducer / earx1
TransducerØ10 mm
CableRemovable
conductorsMMCX - 3.5 mm jack
gold plated
Parts suppliedEarphones iBasso IT01
removable cable
Storage Case
4x silicone tips (black) / pair
6x silicone tips (gray) / pair
2x foam tips shape memory
7 reviews
Très bon intras pour débuter dans l'audio nomade.
Le son est détaillé et la qualité de construction irreprochable.
A ce prix il y a très peu d'équivalent
This review has been posted for iBasso IT01 In-ear monitor High definition Diaphragm 10mm 18 Ohm
Super performance
The iBasso IT01 produce great sound and solid base. Not exaggerated but good.
My only comment: If you have narrow ear canals, you may need to try many of the eartips in order to get a good fit. For my ears, there should be smaller tips included. This is the reason for the 4 stars.
Du tres bon son
Couplé avec un ibasso dx120 synergie parfaite bass medium aigu tout y est, dynamique bonne scène sonore pour le prix difficile de trouver mieux.
excellent rapport qualité prix
commandé le matin, reçu le lendemain, parfait.
une fois trouvé le bon embout (celui qui s'adaptera le mieux à votre conduit d'oreille, le son est parfait . Je l'utilise avec un lecteur Shamling MO
rapport qualité-prix monstrueux !
Après quelques jours d'écoute non -stop, je ne peux que me féliciter d'avoir acheté ce casque. Il est beau, bien fabriqué, fourni avec de nombreux embouts (12 paires ), un joli boitier de rangement. Il sonne très bien, couplé à un lecteur Cowon et des fichiers Hi-Res c'est un vrai plaisir ! Il tient parfaitement dans l'oreille, sans fatigue sur les longues écoutes. Seul regret, dommage que le connecteur jack du câble ne soit coudé, pour plus de solidité. On verra sur la durée. Vraiment content de mon achat et merci aux avis précédents qui m'ont aidé à me décider.
With its extremely fine construction and its original design which directly tackles audiophile exigeances, the IT01 in-ear monitors are a very...
