In-Ear Monitors IEM Dynamic Drivers Ø10.2mm 31 Ohm 111dB 10Hz-30kHz
With impressive sound quality and the ability to adapt to all musical styles and listening styles, the Meze Advar offer an aural finesse that leaves no room for compromise. At the heart of these in-ear monitors is a precisely tuned 10.2mm dynamic driver that delivers a warm, dynamic sound, true to the established Meze Audio signature. The diaphragm of this driver provides impressive control over the entire frequency range, giving way to a smooth and velvety sound.
Here, musicality does not come at the expense of precision, as the Meze Advar brings each note to life, revealing previously unheard details of your music. Moreover, the Advar are easy to accompany and can be associated with any source, thanks to their high sensitivity and low impedance. It offers great precision and fidelity over a wide frequency range, from 10Hz to 30kHz, for an immersive listening experience.
With a shape inspired by the rounded surface of raw hematite and intricately carved curves, the stainless steel shell has an ergonomic contour for comfort.
The body of the earpiece rests lightly on the ear and, together with the over-the-ear lugs, reduces discomfort during long listening sessions. This curved design also helps enhance the sound-isolation properties of the earpiece.
The ear tips have also been carefully selected to provide an optimal fit and seal, effectively conforming to the shape of your ear. Developed by Final Audio, the Type E model also provides improved bass and reduced treble aggression.
Product tyype | In-ear monitors (IEM) |
Drivers | 10.2mm dynamic transducers |
Frequency response | 10Hz - 30kHz |
Impedance | 31Ω |
SPL | 111dB/mW |
Distortion | < 1% @ 1kHz |
Cable conductors | Silver plated copper |
Connectors contacts plating | Gold |
Chassis material | Cast and CNC machined stainless steel |
Body finish | Glossy black chrome plating |
Général | |
Package | Meze Advar 1x Hard case pouch 1x MMCX removal tool 1x Cleaning tool 5x Ear tips pairs (SS, S, M, L, LL) 1x MMCX to Jack 3.5mm cable 1.25m |
Color | Black |
Color | Gold |
Impedance (Ω) | 31 |
Efficiency / Sensitivity (dB) | 111 |
Lowest frequency (Hz) | 10 |
Highest frequency (Hz) | 30000 |
