La forme des intrus est au top! Enfin pour mon oreille, on dirait qu'is l'ont moulée à mon conduit auditif!
By buying this product you get 55 loyalty points
In-ear monitors 5x transducers / 3-way / 106dB / 18 ohm
The best audio technologies in an extremely light case (6.8g), the Shanling ME700s uses no less than five transducers per channel, including 4 custom Armature transducers to offer breathtaking sound reproduction.
These wired monitors work with a detachable MMCX to 2.5mm jack balancedcable. 3.5mm jack and 4.4mm jack adapters ensure excellent interoperability with most of your audio sources.
An excellent sensitivity of 106dB and an impedance of 18 Ohm let your audio source drive effortlessly the ME700. Even when connected to a device with limited amplification capabilities.
Each headset is first equipped with a large dynamic transducer dedicated to the bass. The latter works with a 24K gold-plated diaphrahme which is ideal for absorbing unwanted vibrations while providing a clear and detailed response in the lowest frequencies.
In addition to the dynamic transducer, the ME700 headset uses four symmetrical Armature transducers. The first pair is dedicated to mid / treble while the second pair of transducers delivers the higher frequencies of the audio spectrum. Each of these Armature transducers is a custom version which was modified to strictly comply with Shanling specifications to offer the performance.
The transducers are arranged so as to compensate for the frequency response differentials between one another and with the diaphragm. This design helps to get the most out of each transducer while canceling out phase and time distortion effects. The result is an extremely large and detailed sound image with natural and coherent audio reproduction.
Shanling's ME700s include very high performance Knowless Armature TWFK-30017 transducers. This model is particularly appreciated in the world of IEM for its level of detail in the medium / high range without exaggerated brightness or aggressiveness at the higher top of the spectrum. This allows greater signal clarity without causing listening fatigue.
The supplied cable has 8 cores each composed of 18 high purity silver-plated OFC copper conductors. Each core is protected by an individual TPE sheath before being braided for superior robustness.
The interconnect cable is equipped with MMCX connectors and can be easily replaced in case of loss or breakage. The other end has a standard 2.5mm gold-plated jack connector.
A 3.5mm jack adapter (single-ended) and a second 4.4mm jack adapter (balanced) are included with the ME700. They benefit from the same quality of manufacture as the native connectors. They also ensure excellent intercompatibility with most of your single-ended and unbalanced sources.
All connectors have a SUS316F stainless steel structure (often used in on-board systems in aeronautics). Resistant to impact as well as corrosion, it is an ideal choice for all sensitive moving parts.
Specifications | |||
Type | IEM | ||
Transducers | x5 ( 1x dynamique + 4x Armature custom) | ||
Connectors | Jack 2.5mm + Adapter 3.5mm + Adapter 4.4 mm | ||
Cable | Neotech Silver 1.2m | ||
Impedance | 18Ω | ||
Sensitivity | 106 +/- 3dB | ||
Frequency response | 20 - 40 000hz | ||
Weight | 6.8 g |
Contenu du paquet | |
IEM ME700 | x1 |
Tips (pairs) | x12 |
Leather case | x1 |
Adapter jack 3.5mm | x1 |
Adapter jack 4.4mm | x1 |
Cleaning brush | x1 |
Color | Black |
Impedance (Ω) | 18 |
Efficiency / Sensitivity (dB) | 106.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Hervé B.
Hervé B.
