By buying this product you get 59 loyalty points
In-Ear Monitors IEM 22Ω 105dB 20Hz-40kHz
With the MG600, Shanling offers high-end in-ear headphones with an exceptional design, both internally and externally. Each IEM features a perfectly tuned and optimized 10mm dynamic driver and a beautiful stained maple wood body.
The MG600 is the result of extensive research and experimentation in the field of dynamic drivers. Each earphone incorporates a new-generation dynamic driver in an optimized design, allowing you to take full advantage of this technology.
The MG600's drivers feature an aluminum-magnesium alloy dome for improved performance, especially in the high range. The diaphragm uses a combination of carbon and graphite fiber, offering great rigidity. The whole system is powered by a Japanese high voltage coil and a high performance magnet, ensuring great dynamics and deep bass.
The MG600's semi-open design allows air to move freely through the earpiece to provide a wide soundstage, punchy bass and beautiful dynamics. The balance of sound pressure prevents listening fatigue, even with prolonged use.
The MG600s are dressed in a sublime body of 100 year old maple wood, enriched with pigments and resin, giving these IEMs a unique aesthetic. Always designed in pairs, each one has its own blue gradations, accentuated by golden touches of the most beautiful effect. Moreover, the shape is optimized to fit perfectly in the ear, and the reduced weight of the headphones ensures a perfect wearing comfort.
The cable supplied with the Shanling MG600 also benefits from a very nice construction, with its eight insulated and braided conductors. Six of them are made of high purity monocrystalline copper, the other two of silver-plated copper, ensuring perfect conductivity, each one having its own shielding.
The MG600 cable features a modular connection system, allowing you to change the input connector depending on your source material. A single-ended 3.5mm jack is provided, as well as a balanced 2.5mm and 4.4mm jack. The cable can also be detached from the headphones, the connection being made in MMCX.
The MG600 earphones come with the latest generation of SpinFit CP100 tips. These are uniquely constructed to fit the ear canal perfectly. In addition, a variety of additional ear tips in different sizes are provided.
Product type | In-Ear Monitors (IEM) |
Drivers | Ø10mm dynamic drivers |
Impedance | 22Ω |
Frequency response | 20Hz - 40kHz |
Sensitivity | 105dB ±3dB |
Cable length | 1.3m |
Cable connector | Single-ended Jack 3.5mm Balanced Jack 2.5mm Balanced Jack 4.4mm |
Weight / earphone | 3.3g |
Package | Shanling MG600 1x Single-ended Jack 3.5mm connector 1x Balanced Jack 4.4mm connector 1x Balanced Jack 2.5mm connector 1x Shanling C5 PU leather case 1x Cleaning accessory 11x Eartips pairs |
Color | Blue |
Impedance (Ω) | 22 |
Efficiency / Sensitivity (dB) | 105.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
