VIABLUE T6s Connector Jack 6.35mm Mono Bronze Plated Gold 24k Ø9.5mm (Unit)
VIABLUE T6s JACK 6.3mm Mono Bronze Plaqué Or 24k Ø9.5mm (x2)
Reference : 4645
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
rMono 6.3mm Jackof theseries T6s VIABLUE which can be used in the design of a very high quality modulation cable.
All T6s series connectors are supplied with 2 diameter reducers . These reducers make it possible to adapt the connectors to the diameter of the cable to be used.
The small reducer has an outside diameter of 7.5 mm and an internal diameter of 4.5 mm, thus allowing the use of cables whose diameter can be between 3and 4.5mm.
The large one has an outer diameter of 9.5 mm and an inside diameter of 7.5 mm. It is designed for cables of diameter5 to 7.5mm.
Without these reducers, the T6s connector allows the use of cables of large cross section with a diameter between 7.5 and 9.5mm.
Specifications:
  • connectorMONO
  • Very Rigid Aluminum Body Machined from a Single Piece
  • ContactsBronzePlated Gold 24k
  • Screw Connector to the medium of 2 M4 Screw Length 1.5mm (This is just the screw connector, not the contacts themselves)
  • Accepts Diameter Cables: - 3 to 4.5mm (Small Gearbox Supplied)
    - 5 to 7.5mm (Large Gearbox Supplied)
    - 7.5 to 9.5mm (Without Reducer)
  • LengthTotal:61.2mm
  • Maximum Outside Diameter: 13,5mm
  • Sold by unit
https://www.audiophonics.fr/images2/4645_VIABLUE-T6S-JACK6.3-MONO_1.jpg
https://www.audiophonics.fr/images2/4645_VIABLUE-T6S-JACK6.3-MONO_2.jpg
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
Contacts number2
