Brass plated connector ⌀4mm
This 4.4mm jack connector with a neat carbon finish. is built with gold-plated brass conductors within a painted metal capsule. It offers good conductivity and mechanical resistance.
Its structure is TRRRS (Tip - 3x Ring - Sleeve). It can thus be used to build a very compact balanced connector.
The base of the cable.is protected thanks to a silicon sleeve that protects the cable conductors against twisting and strong pull.
Jack Format | 4.4mm / Balanced TRRRS |
Contacts materials | Brass |
Plating | Gold |
Max cable diameter | Ø 4mm |
Connection Type | Welding |
Weight | 9g |
Body dimensions | ⌀8.42 x 22.5mm |
Total length | 43.5mm |
Color | Silver |
Max cable diameter (mm) | 4.0 |
Mounting type | To weld |
Connectic | Male |
Contacts number | 5 |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
