Aluminium Graduated Knob D Shaft 38x33mm Ø6mm
Knob Aluminium Graduated D Shaft 38x33mm Ø6mm
This Aluminium knob is graduated from 1 to 12. It is fixed with a hexagon socket screw integrated on the flat axis of a potentiometer. Its long grip ensures ideal ergonomics.
Reference : 9497
7,40 €tax incl.
6,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Bouton Aluminium
Bouton Aluminium Gradué Axe Méplat 35x33mm Ø6mm
Product typeButton
MaterialAnodized Aluminium
GraduationFrom 1 to 12
Diameter of the central hole6mm
Locking screwHexa
Base diameter38mm
Total height33mm
Tap diameter22mm
Base thickness3mm
ColorSilver
ColorSilver
ShaftFlat
Internal widthN/A
Internal depthN/A
Internal heightN/A
Sens de lecture des chiffres inversé
Les chiffres défilent correctement de 1 à 12 en tournant le bouton de la gauche vers la droite MAIS on les chiffres sont à l'envers si on les lis en haut du bouton ! EN FAIT IL FAUT QUE l'index soit sous le bouton et non au dessus. Curieux non ?
This review has been posted for Aluminium Graduated Knob D Shaft 38x33mm Ø6mm
This Aluminium knob is graduated from 1 to 12. It is fixed with a hexagon socket screw integrated on the flat axis of a potentiometer. Its long...
