Triple Regulated Linear Power Supply Module IRF9Z34NS +/-15V +5V
Module Alimentation Linéaire Régulé Triple IRF9Z34NS +/- 3.3V à +/- 15V
3.0 / 5
Reference : 14229
26,90 €tax incl.
22,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
Triple linear regulated power supply
This module uses three independant linear regulated power supplies, each exploiting its own recitifer MOSFET IRF9Z34NS driven by a Ti NE5534 OPA.
Each of these power stages works with a variable potentiometer W202 and can thus be adjusted to obtain the desired voltage. The power circuits are independent and can provide voltage of +5V and +/-15V.
Dimensions & Connectors
The PCB is organized so as to make it easy to merge the outputs of power supplies circuits 1 & 2 if needed. This type of arrangement will be particularly useful for obtaining a negative & positive (+/-) DC voltage.
This property makes it an ideal choice for powering advanced DAC modules where digital and analog stages can be powered from separate sources, such as 9038 DAC & output stage modules from IAN CANADA.
TypePower supply
Power supply typelinear regulated
Entries Outputsx3
bridge rectifierIRF9Z34NS
Output voltage+5V and +/-15V (x2)
Dimensions70.6 x 86.3 x 30 mm
distances69.4 x 78.9
InputSolder pad
OutputSolder pad
Output voltage (V)5.0
Output voltage (V)15.0
Output current (A)NC
Input voltage (V)N/A
Power SupplyRegulated Linear Power Supply
moyen
la derniere regulation ne fonctionne pas, c est dommage
This review has been posted for Triple Regulated Linear Power Supply Module IRF9Z34NS +/-15V +5V
