Power Supply Module DC TTA1943 LM317 with Filtering 20V
Module alimentation linéaire DC LM317 37V
Reference : 14294
19,90 €tax incl.
16,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Module linear regulated power supply
EMI / RFI Filter TTA1943 LM317 20V 2A
filtered audiophile line feed
This linear power module has its own EMI / RFI filter with an additional connector for properly connecting a toroidal transformer.
It uses a  Toshiba TTA1943 MOSFET driven by a LM317 for high precision in the low and moderate powers.
Effective filtration occurs through a combination of 4700μF capacity electronic capacitors  for a maximum voltage of 32V. Each power rail also benefits from a copper shelf for output filtering.
The output voltage is adjustable using a potentiometer mounted directly on the PCB. The power supply is capable of providing up to 20V / 2A (recommended). with occasional peaks up to 4A.
Dimensions and distances
All values ​​are given in millimeters (mm)
TypeLinear regulated power supply
EMI / RFI FilterYes
adjustable voltageup to 20V
Input Voltage20V Max
ConnectorsScrew terminals
RegulatorTTA1943 driven LM317
Dimensions100 x 100 x 30 mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)20.0
Output current (A)2.0
Input voltage (V)20.0
Power SupplyRegulated Linear Power Supply
