ATOHM LD130CR08 Speaker Driver Midbass 60W 8 Ohm 89dB Ø13cm
ATOHM LD130 CR08 Medium 13cm (Unit)
Reference : 2251
99,00 €tax incl.
82,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The LD130 CR08 is identical in design to the LD130 CR04. However its impedance of 8 Ohm allows the parallel of 2 units.
The core has a copper ring which significantly reduces the distortions by third-order harmonic by canceling the creation of induced currents in the pole pieces.
It is equipped with a paper membrane combined with a peripheral suspension technology LDS ™ characterized by a very specific profile limiting the phenomena of parasitic reflections and standing waves at the mouth of the cone.
This modele allows the realization of systems according to the configurations "medium - tweeter - medium", "medium - medium - tweeter" or possibly "doublet".
Find the complete datasheet in the documents below.
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)130.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)7.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
2 reviews
Great driver !
I bought this to replace an identical failed driver in an Onix Reference 2 Mk 2 speaker. Great speaker, my old speakers sound new again ! Crisp, clean low-end.
This review has been posted for ATOHM LD130CR08 Speaker Driver Midbass 60W 8 Ohm 89dB Ø13cm
Particulièrement bon
Je l'utilise dans une enceinte DIY entre 300 - 3khz.
Très linéaire dans l'axe et hors axe.
Capable de fonctionner en charge close.
Excellent, pas de coloration.
Rendu très naturel.
