ATOHM LD165CR08 Speaker Driver Midbass 90W 8 Ohm 87dB Ø16.5cm
ATOHM LD165CR08 Boomer grave-medium Speaker 16cm (Unit)
Reference : 2255
125,00 €tax incl.
104,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
This reference is very similar to the LD165CR04. The differences reside in the use of an inverted core cache and a voice coil whose impedance of 8 Ohm allows the parallel connection of 2 units.
Ce boomer grave-medium is particularly intended to constitute the serious way of a system 2 or 3 channels bass-reflex of very high level.
Find the complete datasheet in the documents below.
Speaker Power (W RMS)90.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)160.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)7.0
