Woofer efficace pour mon premier projet. Je n'ai pas fait de crossover pour cet essai mais il mérite une légère atténuation des mediums (dans mon cas) et une augmentation des graves. (baffle step).
Je recommande pour les débutants dans mon cas !
The Dayton Audio PS95-8 is a full-range loudspeaker from the brand's Point Source range. It features a curved cone made of 100% natural fibers. This results in dynamic sound reproduction ranging from punchy bass to very high treble, which is the very special feature of this Dayton audio PS95-8 loudspeaker; producing both articulate, balanced bass and midrange, as well as extended treble. In addition, the copper cap reduces inductance and distortion. This loudspeaker has a power handling of 10W for 8 ohms and an extended frequency response from 110Hz to 20kHz. Its compact size allows it to be easily integrated into small satellite desktop speakers or narrow "needle" style loudspeaker towers for ultra-high performance.
This Dayton Audio PS95-8 loudspeaker covers the entire sound spectrum, including clear, natural, detailed highs. That's why the addition of a tweeter isn't necessarily necessary when using the PS95-8.
KEY POINTS:
Product type | Speaker driver full range |
Nominal output power (RMS) | 10W |
Max. output power (max) | 20W |
Impedance | 8Ω |
Fréquency response | 110Hz à 20kHz |
Sensibility | 85.56dB 2.83V/1 m |
Voice coil diameter | 20mm |
Resonant frequency (FS) | 119.8Hz |
DC resistance (Re) | 7.1Ω |
Voice coil inductance (Le) | 0.63 mH @1kHz |
Mechanical Q (Qms) | 7.33 |
Electromagnetic Q (Qes) | 0.8 |
Total Q (Qts) | 0.72 |
Compliance equivalent volume (Vas) | 0.03 pi³ |
Mechanical suspension compliance (Cms) | 0.79mm/N |
BL Product (BL) | 3.83Tm |
Diaphragm Mass Inc. Airload (MMS) | 2.2g |
Maximum linear excursion (Xmax) | 2.5mm |
Cone surface (Sd) | 28.3cm² |
Cone / diaphragm material | Polypropylene |
Surround material | Caoutchouc |
Voice coil wire material | Copper |
Acoustic coil | Kapton® / Polyimide |
Frame material | Cast aluminium |
Magnet | Ferrite |
Overall outside diameter | 76.8mm |
Baffle cutout diameter | 69.8mm |
Overall depth | 52.3mm |
Mounting holes | 4 |
Package | 1x Dayton Audio PS95-8 full-range speaker driver |
Speaker Power (W RMS) | 10.0 |
Speaker Type | Full range |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 90.0 |
Diaphragm type | Polypropylene |
Efficiency / Sensitivity (dB) | 83.0 |
Max Linear Excursion (Xmax) (mm) | 2.5 |
Lowest frequency (Hz) | 110 |
Highest frequency (Hz) | 20000 |
Average votes 4.3 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Simon M.
Tim N.
Ludovic L.
Elio M.
