FOUNTEK FW200 Speaker Driver Midbass 75W 8 Ohm 88dB 35Hz - 3000Hz Ø20cm
FOUNTEK FW200 Haut parleur Médium 20cm
Reference : 5928
47,90 €tax incl.
39,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
This model has been replaced by its big brother, the FOUNTEK FW222.
he Fountek FW200 woofer is a rugged woofer with an attractive aluminum cone, a high-strength cast aluminum frame and a motor structure optimized for low distortion .
The result is a clean, neutral bass to midrange sound with no coloration from paper, Kevlar or carbon diaphragms. Its low resonance of 35 Hz allows you to obtain high quality bass in a small volume.
Magnet system
Overall Dimensions
217x88.8mm
Magnet system type
ferrite
Net.Weight
1.7Kg
Magnetic Gap Height
5.8mm
Nominal Power Handlng
75 W
B Flux Density
1.0T
Nominal Impedance
8 Ohms
Bl Product
6.83Tm
Sensitivity 1W/1M
88dB
Max Linear Excursion
4.35mm+/-
Frequency Response
35-3,000Hz
T/S Parameter
Resonant frequency
35.7Hz
Cms
0.948mm/N
Voice Coil
Sd
213.8cm^2
Voice Coil Diameter
36mm
Vas
61.6 litre
Voice Coil Height
14.5mm
Mmd
19.129gm
Voice Coil Former
aluminum
Mms
20.927gm
Voice Coil Wire
copper
Qms
2.258
Number of Layers
2
Qes
0.683
DC Resistance
6.8 Ohms
Qts
0.525
https://www.audiophonics.fr/images2/5928/5928_FOUNTEK200_2.jpg
https://www.audiophonics.fr/images2/5928/5928_FOUNTEK200_3.jpg
Speaker Power (W RMS)75.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)200.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)35
Highest frequency (Hz)3000
