Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Ultra rigid cone made up of aluminum and magnesium alloy coated on the surface with a damping material promoting dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
Specifications:
HiVi B4N:Dimensions
HiVi B4N:Frequency Response
HiVi B4N:Impedance Curve
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 102.0 |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | 85.0 |
Max Linear Excursion (Xmax) (mm) | 3.2 |
Lowest frequency (Hz) | 60 |
Highest frequency (Hz) | 4000 |
