HiVi SWANS D6.8 High Performance Speaker 6.5 "
HiVi D6.8 Haut-Parleur Grave/Médium Haute Performance 6.5"
Reference : 4793
137,00 €tax incl.
114,17 € tax excl.
Available
Shipping date: 26-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
https://www.audiophonics.fr/images2/Swans_Logo.gif
HiVi's "D" loudspeaker range is a synthesis of all the technological advances made in recent years in the field of electroacoustics.
It is also the expression of the extraordinary know-how of a team of engineers and music lovers resolutely in the forefront.
Injected polypropylene cone
of mineral elements in order to densify the structure and improve rigidity.
Peripheral suspension in natural rubberloudspeaker to the loudspeaker, and participating in absorbing parasitic vibrationsoriginating at the surface of the cone
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor, combination of 2 magnets, one in Neodymium, the other in ceramics, mounted in symmetrical and ventilated
Can be used as a severe / medium unit on a 2-way system , or as a medium loudspeaker on a 3-way system more sophisticated.
https://www.audiophonics.fr/images2/4793_SWANS-HIVI-D6.8_2.jpg
https://www.audiophonics.fr/images2/4793_SWANS-HIVI-D6.8_3.jpg
Specifications:
  • Nominal Impedance:
  • Resonant Frequency: 43Hz
  • Rated Power:60W
  • Maximum Power Output:120W
  • Sensitivity (2.83v / 1m): 83dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 76mm
  • Length Coil:15.5mm
  • Mounting Type:Kapton
  • Composition Coil:Aluminum Wires Copper Plated
  • Composition Magnetic Circuit: Neodymium + Ceramic
  • BL:8.9
  • Hey :5.0mm
  • XmaX:5.3mm
  • Cms:647
  • Qms:5.21
  • Qes:0.49
  • Qts:0.45
  • Mms:21.9g
  • Sd:0.0121m2
  • Vas:13.5L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 10L
  • Recommended Cut-Off Frequency -3dB: 44Hz
  • Weight:1.7Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4793_SWANS-HIVI-D6.8_4.jpg
HiVi D6.8:Dimensions
https://www.audiophonics.fr/images2/4793_SWANS-HIVI-D6.8_6.jpg
HiVi D6.8:Frequency Response
https://www.audiophonics.fr/images2/4793_SWANS-HIVI-D6.8_5.jpg
HiVi D6.8:Impedance Curve
Speaker TypeMidrange
Colissimo - TNT - SoColissimo
2 reviews
Je ne suis pas donc fou ! Je me disais bien qu'il ressemblait au dynaudio. Merci !
This review has been posted for HiVi SWANS D6.8 High Performance Speaker 6.5 "
Bonjour, cela vas faire plus d'un an que j'ai acquis ces HP et j'en suis pleinement satisfait! Septique au début (seul un site allemand en faisait des éloges jusqu'à les juger meilleur que les originaux...) mais j'ai eu la chance de posséder une paire de Dynaudio Esotec 15W75 en comparaison et surprise, les clones chinois s'en sortent mieux, plus doux et naturelle malgré une différence de 3 dB de rendement.
L'effet "psychologique" aurait du me dire NON les Dynaudio sont mieux mais après les avoir fait écouter à divers passionnés (en leur faisant croire que les 2 étaient des Dynaudio) le constat était le même, sans parler de la claque à l'annonce de "clones chinois".
Donc à acheter sans hésiter!
P.S. : je les drive avec un Monstre 8W Hiraga et s'en sortent étrangement bien.
