HiVi SWANS D8.8 High Speaker Driver Midbass Shielded 150W 8 Ohm 86dB 40Hz - 2000Hz Ø 20.3cm
HiVi D8.8 Haut-Parleur Grave/Médium Haute Performance 8"
By buying this product you get 25 loyalty points
Reference : 4796
259,00 €tax incl.
215,83 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
HiVi's "D" loudspeaker range is a synthesis of all the technological advances made in recent years in the field of electroacoustics.
It is also the expression of the extraordinary know-how of a team of engineers and music lovers resolutely in the forefront.
Injected polypropylene cone
of mineral elements in order to densify the structure and improve rigidity.
Peripheral suspension in natural rubberloudspeaker to the loudspeaker, and participating in absorbing parasitic vibrationsoriginating at the surface of the cone
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor, combination of 2 magnets, one in Neodymium, the other in ceramics, mounted in symmetrical and ventilated
https://www.audiophonics.fr/images2/4796_SWANS-HIVI-D8.8_1.jpghttps://www.audiophonics.fr/images2/4796_SWANS-HIVI-D8.8_2.jpg
https://www.audiophonics.fr/images2/4796_SWANS-HIVI-D8.8_3.jpg
Specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 32Hz
  • Rated Power:150W
  • Maximum Power Output:300W
  • Sensitivity (2.83v / 1m): 86dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 100mm
  • Length Coil:23.5mm
  • Mounting Type:Kapton
  • Composition Coil:Aluminum Wires Copper Plated
  • Composition Magnetic Circuit: Neodymium + Ceramic
  • BL:12.9
  • Hey :7.0mm
  • XmaX:8.3mm
  • Cms:457.8
  • Qms:4.36
  • Qes:0.44
  • Qts:0.40
  • Mms:53.1g
  • Sd:0.0241m2
  • Vas:37.8L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 30L
  • Recommended Cut-Off Frequency -3dB: 35Hz
  • Weight:3.5Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4796_SWANS-HIVI-D8.8_4.jpg
HiVi D8.8:Dimensions
https://www.audiophonics.fr/images2/4796_SWANS-HIVI-D8.8_5.jpg
HiVi D8.8:Frequency Response
https://www.audiophonics.fr/images2/4796_SWANS-HIVI-D8.8_6.jpg
HiVi D8.8:Impedance Curve
Speaker Power (W RMS)150
Speaker TypeMidbass
Impédance8
Diamétre Haut Parleur (cm)203
Diaphragm typePolypropylene
Rendement86
Xmax8.3
Lowest frequency40
Highest frequency2000
Colissimo - TNT - SoColissimo
