HiVi SWANS DMA-A Speaker Driver Midrange Dome 80W 5 Ohm 92dB Ø5cm
HiVi DMA-A Haut-Parleur Médium à Dôme 50mm
Reference : 4769
59,90 €tax incl.
49,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
https://www.audiophonics.fr/images2/Swans_Logo.gif
"If you still think that China can only produce low-end speakers, review your judgment!"br>Because this medium DMA unit really does not have to pale in front of its European competition, far from necessary.
Yet, even though HiVi's head office is located in Canada, it is indeed in China that the production units are based! "
Vance Dickason, American Authority Magazine
This latest-generation model incorporates the principles that made the former DMA-A unit's success esteem, and improves the concept to achieve a new performance threshold.
This mid-range speaker now has a dome conical fabric of 50mm diameter , the surface of which is covered with a compound specifically chosen for its non-standard damping properties .
The winding of the moving part uses copper-plated aluminum wire permitting superior power handling, and reducing the resonance frequency to an optimum value for a better connection with the woofer.
The magnetic circuit composed of 2 symmetrically mounted armored magnets is based on a technology owner HiVi to allow a consequent increase in sensitivity, and a drastic reduction of harmonic distortions.
Thanks to its design and its mass, this exceptional engine also participates in the release of excess calories from the voice coil , assisted in this by a large acoustically ventilated chamber .
The result is a linear frequency sound, full of vitality, and the absence of distortion or coloring gives the sound scene a truly exceptional amplitude and naturalness.
https://www.audiophonics.fr/images2/4768_SWANS-HIVI-DMA-A_1.jpghttps://www.audiophonics.fr/images2/4768_SWANS-HIVI-DMA-A_2.jpg
Specifications:
  • Nominal Impedance:5Ω
  • Resonant Frequency: 630Hz
  • Rated Power:80W
  • Sensitivity (2.83v / 1m): 92dB
  • Resistance DC:/ Strong>4.3Ω
  • Diameter Coil: 50mm
  • Composition Coil:Wire Aluminum Plated Copper
  • Number of Layers:2
  • Chassis: Aluminum
  • Composition Magnetic Circuit: Double Ferrite
  • Magnetic Shielding: Yes
  • Recommended Cutoff Frequencies: > 800Hz / <6000Hz
  • Weight: 1.6Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4768_SWANS-HIVI-DMA-A_6.jpg
HiVi DMB-A: Dimensions
https://www.audiophonics.fr/images2/4768_SWANS-HIVI-DMA-A_4.jpg
HiVi DMB-A: Frequency Response
https://www.audiophonics.fr/images2/4768_SWANS-HIVI-DMA-A_5.jpg
HiVi DMB-A: Impedance curve
Speaker Power (W RMS)80.0
Speaker TypeMidrange
Impedance (Ω)5
Loudspeaker diameter (mm)50.0
Efficiency / Sensitivity (dB)92.0
2 reviews
super medium. remplacement HP réussi!
en remplacement de HP sur revox symbol B. le couple tweeter et medium hivi s'est reveillé redoutable. qualité audio au top. timbres respectés. pas de brillance exagérée. le son reste doux même à niveau élevé. plus grande spatialisation. je redécouvre mes enceintes. super rapport qualité / prix. je recommande.
This review has been posted for HiVi SWANS DMA-A Speaker Driver Midrange Dome 80W 5 Ohm 92dB Ø5cm
medium a dôme 50
un médium imposant du plus belle aspect et qualité au début pas évident car toujours très présent
au début il joue en actif et par la suite je l ai filtré
il est devenue plus doux et moins directionnelle
bref qualité prix il me convient parfaitement bien
