HiVi SWANS F5 Speaker Driver Midbass Kevlar 35W 8 Ohm 86dB Ø 12.7cm
HiVi F5 Haut-Parleur Grave/Médium Kevlar 5"
Reference : 4788
62,00 €tax incl.
51,67 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
HiVi's "F" loudspeaker range is a synthesis of all the technological advances made in the last few years in the field of electroacoustics.
It is also the expression of the extraordinary know-how of a team of engineers and music lovers resolutely in the forefront.
Ultra rigid cone from a learned combination of Kevlar and paper
Peripheral suspension in natural rubberGerman-made loudspeaker system that provides long-lasting loudspeaker performance and absorbing parasitic vibrationsoriginating at the surface of the cone
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor consisting of 2 magnets mounted in symmetrical and ventilated
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
Can be used as a severe / medium unit on a 2-way system ,or as a medium loudspeaker on a 3-way system more sophisticated.
https://www.audiophonics.fr/images2/4780_SWANS-HIVI-F5_1.jpghttps://www.audiophonics.fr/images2/4780_SWANS-HIVI-F5_2.jpg
https://www.audiophonics.fr/images2/4780_SWANS-HIVI-F5_3.jpg
Specifications:
  • Nominal Impedance:
  • Resonant Frequency: 52Hz
  • Rated Power:35W
  • Maximum Power Output:70W
  • Sensitivity (2.83v / 1m): 86dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:10.4mm
  • Mounting Type:Kapton
  • Composition Coil:Aluminum Wires Copper Plated
  • Composition Magnetic Circuit: Double Ferrites
  • Magnetic Shielding:/ Strong>Yes
  • BL:8.3
  • Hey :5.0mm
  • XmaX:2.7mm
  • Cms:828
  • Qms:4.31
  • Qes:0.36
  • Qts:0.33
  • Mms:11.5g
  • Sd:0.0079m2
  • Vas:7.3L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 8L
  • Recommended Cut-Off Frequency -3dB: 47Hz
  • Weight:1.6kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4780_SWANS-HIVI-F5_4.jpg
HiVi F5:Dimensions
https://www.audiophonics.fr/images2/4780_SWANS-HIVI-F5_5.jpg
HiVi F5:Frequency Response
https://www.audiophonics.fr/images2/4780_SWANS-HIVI-F5_6.jpg
HiVi F5:Impedance Curve
Speaker Power (W RMS)35
Speaker TypeMidbass
Impédance8
Diamétre Haut Parleur (cm)127
Diaphragm typeKevlar
Rendement86
Xmax2.7
Colissimo - TNT - SoColissimo
