HiVi U2S Speaker Driver Full Range Anodized Aluminum 5W 8 Ohm 83dB 200Hz - 20kHz Ø5cm
HiVi U2S Haut-Parleur Large-Bande Aluminium Anodisé 2"
Reference : 4804
36,90 €tax incl.
30,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
https://www.audiophonics.fr/images2/Swans_Logo.gif
Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Rigid cone, Anodized aluminum coated on the surface with a damping material promoting dynamic stability
Peripheral suspension in transparent rubber
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor in neodymium
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
https://www.audiophonics.fr/images2/4803_SWANS-HIVI-U2S_1.jpghttps://www.audiophonics.fr/images2/4803_SWANS-HIVI-U2S_2.jpg
https://www.audiophonics.fr/images2/4803_SWANS-HIVI-U2S_3.jpg
specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 290Hz
  • Rated Power:5W
  • Sensitivity (2.83v / 1m): 83dB
  • Resistance DC:/ B>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:6mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: neodymium
  • Magnetic Shielding:/ B>Yes
  • BL:3.0
  • Hey :2.5mm
  • XmaX:1.8mm
  • Cms:261
  • Qms:5.17
  • Qes:1.43
  • Qts:1.12
  • Mms:1.2g
  • Sd:0.0013m2
  • Vas:0.1L
  • Recommended Type of Load: Close
  • Recommended Load Volume: 0.2L
  • Recommended Cut-Off Frequency -3dB: 245Hz
  • Weight:0.1Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4803_SWANS-HIVI-U2S_4.jpg
HiVi U2S:Dimensions
https://www.audiophonics.fr/images2/4803_SWANS-HIVI-U2S_5.jpg
HiVi U2S:Frequency Response
https://www.audiophonics.fr/images2/4803_SWANS-HIVI-U2S_6.jpg
HiVi U2S:Impedance Curve
Speaker Power (W RMS)5.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)50.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)83.0
Lowest frequency (Hz)200
Highest frequency (Hz)20000
