MONACOR SP-60/4 Speaker Driver Midbass 30W 4 Ohm 90dB Ø 10cm
Monacor SP-60/4 Woofer 4 Ohm Ø 10cm
4.0 / 5
Reference : 1198
14,90 €tax incl.
12,42 € tax excl.
Available
Shipping date: 13-12-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Medium Hi-Fi, 60 W MAX , 8 Ω (/ 8) and 4 Ω (/ 4) subwoofers. The Monacor SP60 speaker is a reference, a classic standard of small diameter speakers. It reconciles 90dB of output with a wide bandwidth.
The paper membrane has round corrugations avoiding the usual staining. Decompression and cooling by the core through the magnet allows a release of heat from the coil. Moreover, the loudspeaker is exemplary.
For miniature PC speakers, Hi-Fi, line array or any quality request in a restricted volume.
The best loads are obtained in quarter wave load (TQWT) and Bass Reflex. To be coupled with a small 19 / 20mm tweeter or a Monacor SP95SR ribbon tweeter.
Also suitable for DIY design of satellites in close loads with tweeters and a subwoofer.
Impedance (Z) 4 Ω
Resonance frequency (fs) 65 Hz
Maximum bandwidth f3-8000 Hz
Maximum power 60 W MAX
Rated power (P) 30 W RMS
Average sound pressure (1 W / 1 m) 90 dB
Compliance susp. (Cms) 0.8 mm / N
Moving mass (Mms) 4 g
Mechanical overvoltage. (Qms) 2.10
Electrical overvoltage (Qes) 0.64
Fact. total surge (Qts) 0.49
Volume equ. (VAS) 6 l
</ Span> DC resistance. (Re) 3.3 Ω
Force factor (BxL) 2.9 Tm
Inductance coil (The) 0.2 mH
Coil diameter 25.5 mm
</ Span>
Coil holder Alu
Linear Excursion (X MAX ) ±2 mm
Transmitting surface (Sd) 55 cm 2
Magnet Weight 10 oz.
Weight 0.9 kg
[Img-20584-left-thickbox_default]
Monacor SP60
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (cm)110
Diaphragm typePaper
Efficiency (dB)90
Xmax (mm)2
Highest frequency8000
Colissimo - TNT - SoColissimo
ahhh le sp 60
Voici un papy de 30 ans qui assure toujours
Quelques litres un condo sur le tweeter et c est parti
Ce n est pas le meilleur hp du monde mais pour une petite anceinte d ambiance c est un must
Avec un tweeter amt ca marche d enfer avec un lm 3886 c est encore mieux
Je mange avec lui tous les jours
Quel talent
This review has been posted for MONACOR SP-60/4 Speaker Driver Midbass 30W 4 Ohm 90dB Ø 10cm
