MONACOR SPH-130AL Speaker Driver Midbass 50W 8 Ohm 88dB Ø 15.5cm
Monacor SPH-130AL
Reference : 830
69,90 €tax incl.
58,25 € tax excl.
Hi-Fi, 100 W MAX , 8Ω Bass-Loudspeaker
Aluminum diaphragm and dust cover, highly dynamic, high bandwidth, for High End speakers, for example. An ideal loudspeaker for small speakers.
blank.gif Impedance (Z) blank.gif 8 Ω
blank.gifResonance frequency (fs) blank.gif 48 Hz
blank.gif Maximum bandwidth blank.gif f3-4500 Hz
blank.gif Maximum power blank.gif 100 W MAX
blank.gif Rated power (P) blank.gif 50 W RMS
blank.gif Average sound pressure (1 W / 1 m) blank.gif 88 dB
blank.gif Compliance susp. (Cms) blank.gif1.2 mm / N
blank.gif Moving mass (Mms) blank.gif 9 g
blank.gif Mechanical overvoltage. (Qms)blank.gif 5.07
blank.gif Electrical overvoltage (Qes) blank.gif 0.34
blank.gif Fact. total surge (Qts) blank.gif 0.32
blank.gif Volume equ. (VAS) blank.gif 10.8 l
blank.gif blank.gif </ Font>
blank.gif DC resistance. (Re) blank.gif 6.4 Ω
blank.gif Force factor (BxL) blank.gif 7.22 Tm
blank.gif Inductance coil (The) blank.gif 0.6 mH
blank.gif Coil diameter blank.gif 25 mm
blank.gif Coil holder blank.gif Kapton
blank.gif Linear Excursion (X MAX )blank.gif ± 2.3 mm
blank.gif Transmitting surface (Sd) blank.gif 80 cm 2
blank.gif Magnet Weight blank.gif 15.6 oz.
blank.gif Weight blank.gif 1 kg
PDF-Download
PDF-Download
Speaker Power (W RMS)50
Speaker TypeMidbass
Impédance8
Diamétre Haut Parleur (cm)155
Diaphragm typeAluminium
Rendement88
Xmax2.3
Highest frequency4500
Colissimo - TNT - SoColissimo
