MONACOR SPH-135TC Speaker Driver Midbass 2x30W 2x8 Ohm Ø 13cm
Monacor SPH-135TC
Reference : 832
45,70 €tax incl.
38,08 € tax excl.
This product is no longer in stock
Bass-mid-speaker, 2 x 60 W MAX , 2 x 8 Ω
Double coil, polypropylene membrane, good attenuation of mediums, for miniature subwoofer or for loudspeaker of library, 2 ways.
Impedance (Z)2 x 8 Ω
Resonance frequency (fs)40 Hz
Maximum bandwidthf3-6000 Hz
Freq. cut. (fmax).4000 Hz
Maximum power2 x 60 W MAX
Rated power (P)2 x 30 W RMS
Pressure sound. (1W / 1m)85 dB
Compliance susp. (Cms)1.69 mm / N
Moving mass (Mms)8.9 g
Mechanical resistance (Rms)0.7 kg / s
Smech. (Qms)3.44
Electrical overvoltage (Qes)0.48
Fact. total surge (Qts)0.42
Volume equ. (VAS)16 l
DC resistance. (Re)2 x 7.5 Ω / 3.8 Ω
Inductance coil. (The)2 x0.6 mH / 0.6 mH
Coil diameter20 mm
Coil holderAlu
Height winding10.5 mm
Air gap height6 mm
Linear Excursion (X MAX )± 2.25 mm
Transmitting surface (Sd)95 cm 2
Flight. air displaced (Vd)21.4 cm 3
Force factor (BxL)4.2 Tm
Ref. (No)0.2%
Magnet diameter100 mm
Magnet Weight13.3 oz.
cuttingØ 123 mm
Mounting depth 70 mm
Dimensions138 x 138 mm
Weight1.2 kg
Recommended Min Volume
<img src = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" />
closed10 l
bass reflex20 l
PDF-Download
</ A>
PDF-Download
Speaker Power (W RMS)30
Speaker TypeMidbass
Impédance8
Diamétre Haut Parleur (cm)130
Colissimo - TNT - SoColissimo
