MONACOR SPH-170C Speaker Driver Midbass 60W 8 Ohm 88dB Ø18cm
Monacor SPH-170C
Reference : 1184
129,00 €tax incl.
107,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Series of subwoofers and low-medium Hi-Fi made with the utmost care and an elegant design. Aluminum bowl, carbon fiber membrane, deep bass.
120 W Max , 8 Ω,
very wide diaphragm, very little distortion allowing natural restitution; well suited for use as a bass-medium loudspeaker in 2-way systems, requiring a low volume.
Impedance (Z)8 Ω
Fresonance frequency (fs)38 Hz
Maximum bandwidthf3-3500 Hz
Maximum power120 W MAX
Rated power (P)60 W RMS
Average sound pressure (1 W / 1 m)88 dB
Compliance susp. (Cms)1.06 mm / N
Moving mass (Mms)16.43 g
Mechanical overvoltage. (Qms)7.22
</ Font>
Electrical overvoltage (Qes)0.27
Fact. total surge (Qts)0.26
Volume equ. (VAS)24 l
DC resistance. (Re)6 Ω
Force factor (BxL)9.44 Tm
Inductance coil (The) </ Font>0.8 mH
Coil diameter37 mm
Coil holderKapton
Linear Excursion (X MAX )± 4 mm
Transmitting surface (Sd)127 cm 2
Magnet Weight21 oz
PDF Download
PDF Download
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)180.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)3500
