MONACOR SPH-175 Speaker Driver Midbass 60W 8 Ohm 90dB
Monacor SPH-175
Reference : 839
54,90 €tax incl.
45,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
Bass-midrange speaker, 100 W MAX , 8 Ω
Specially coated paper membrane, rubber suspension, optimized aluminum bowl, the ideal speaker for 2-way systems.
Inductance coil. (The)
 Impedance (Z) 8 Ω
 Resonance frequency (fs) 33 Hz
 Maximum bandwidth f3-5000 Hz
 Freq. cut. (fmax). 3000 Hz
  Maximum Power  100 W MAX
 Rated power (P) 60 W RMS
 Pressure sound. (1W / 1m) 90 dB
 Compliance susp. (Cms) 1.86 mm / N
 Moving mass (Mms) 12.5 g
 pan>
 Mechanical resistance (Rms) 1.3 kg / s
 Mechanical overvoltage. (Qms)  1.98
 Electrical overvoltage (Qes) 0.43
 Fact. total surge (Qts) 0.35
 Volume equ. (VAS) 48 l
 DC resistance. (Re) 5.7 Ω
  0.5 mH
 Coil diameter 25 mm
 Coil holder Alu
 Height winding 10 mm
 Air gap height 6 mm
 pan>
 Linear Excursion (X MAX ) ± 2 mm
 Transmitting surface (Sd) 137 cm 2
 Flight. air displaced (Vd) 27.4 cm 3
 Force factor (BxL) 6 Tm
 Ref. (No) 0.4%
 Magnet diameter 84 mm
  Magnet weights 12.5 oz.
 cutting Ø 162 mm
 Mounting depth 70 mm
 Dimensions 177 x 177 mm
 Weight 1.2 kg
 Recommended Min Volume
 closed 16 l
 bass reflex 35 l
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)175.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)5000
