MONACOR SPH-176 Speaker Driver Midbass 70W 8 Ohm 90dB
Monacor SPH-176
Reference : 840
63,90 €tax incl.
53,25 € tax excl.
Shipping date: 28-03-2024.
Shipping from France
Billing in France
Technical support in France
SPH-176: this high-quality speaker, made in Germany, meets all the requirements of a modern hi-fi bass-loudspeaker for a particularly attractive price; focus on the perfect centering of the coil, large linear travel, suspension with a profile rectifying frequency band and exceptional Thiele and Small parameters for bass.
High-quality Hi-Fi bass-speaker, 120 W MAX , 8 Ω
This bass-midrange speaker with a paper membrane with a good pulse, a rubber suspension, optimized properties in the bass, makes it possible to produce deep bass speakers and a high degree of leveling. This speaker can be used as a 2-way Hi-Fi speaker, in dual loudspeaker systems and even very small subwoofers.
Klang + Ton 6/03
"The SPH-176 is almost the ideal image of a conventional bass-midrange speaker."
ILMAG 11
"The Number One SPH-176 is a classic speaker with featuresmodernists who are interested in it. A successful combination. "
+ very linear frequency response
+ many successful solutions
+ large linear excursion
+ very good price
 Impedance (Z) 8 Ω
 Resonance frequency (fs) 39 Hz
 Maximum bandwidth f3-4500 Hz
 Maximum power 120 W MAX
 Rated power (P) 70 W RMS
 Average sound pressure (1 W / 1 m) 90 dB
 Compliance susp. (Cms) 1.01 mm / N
  Moving mass (Mms)  14 g
 Mechanical overvoltage. (Qms) 2.27
 Electrical overvoltage (Qes) 0.44
 Fact. total surge (Qts) 0.37
 Volume equ. (VAS) 27 l
 DC resistance. (Re) 6.6 Ω
 Force factor (BxL) 7.7 Tm
 Inductance coil (The) 0.75 mH
 Coil diameter 25 mm
 Coil holder Alu
 Linear Excursion (X MAX ) ± 5.5 mm
 Transmitting surface (Sd) 140 cm 2
 Magnet Weight 16 oz.
 Weight 1.25 kg
Speaker Power (W RMS)70.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)176.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)5.5
Lowest frequency (Hz)N/A
Highest frequency (Hz)4500
