MONACOR SPH-210 Hi-Fi Speaker Driver Midbass 50W 8 Ohm 90dB Ø19cm
Monacor SPH-210
Reference : 842
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
 Hi-Fi, 100 W MAX , 8 Ω Hi-Fi Bass Loudspeaker
Loudspeaker for any type of use as bass and low-mid in 2 or 3-way speakers and as a replacement for older speaker models.
Klang + Ton 6/01
"It's always amazing how well the MONACOR INTERNATIONAL speakers are positioned in the competition.
 Impedance (Z) 8 Ω
 Resonance frequency (fs) 28 Hz
 Maximum bandwidth f3-4000 Hz
 Freq. cut. (fmax). 3500 Hz
 Maximum power 100 W MAX
 Rated power (P) RMS= 50 RMS
 Pressure sound. (1W / 1m) 90 dB
 Compliance susp. (Cms) 1.32 mm / N
 Moving mass (Mms) 24.5 kg
 Mechanical resistance (Rms) 2.0 kg / s
 Mechanical overvoltage. (Qms) 2.14
 Electrical overvoltage (Qes) 0.27
 Fact. total surge (Qts) 0.24
 Volume equ. (VAS) 81 l
 DC resistance. (Re) 6.5 Ω
 Inductance coil. (The) 1.0 mH
 Coil diameter 35.5mm
 Coil holder Alu
 Height winding 15 mm
 Air gap height 8 mm
 Linear Excursion (X MAX ) ± 3.5 mm
 Transmitting surface (Sd) 210 cm 2
 Flight. air displaced (Vd) 73.5 cm 3
 Force factor (BxL) 10.3 Tm
 Ref. (No) 0.6%
 Magnet diameter 120 mm
 Magnet Weight 29.5 oz.
 cutting Ø 183 mm
 Mounting depth 99 mm
 Dimensions Ø 210 mm
 Weight 2.42 kg
 Recommended Min Volume
 closed 15 l
 bass reflex 27 l
Speaker Power (W RMS)50.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)190.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)3.5
Lowest frequency (Hz)N/A
Highest frequency (Hz)4000
